Agitator is slipping when in wash mode. - Washing Machines
  • Washing Mach... Master
  • 8,220 Answers
Your agitator has a set of 4 dogs that propel the upper portion of the agitator. Over time the face on those dogs gets smooth and will not engage the inner walls of the upper agitator. The part number is 80040. Not very hard to repair. Get the top off and the seal so that you can access the nut holding the agitator in. Remove that nut and the agitator can be removed. Sit the agitator on the floor and hold it down with your feet. Grab the upper portion and snatch it away from the lower portion. Replace those dogs.
Posted on Jun 01, 2009
Why does the agitator seem to slip when washing?
That is due to overloading most likely. they do have a clutch that will slip to prevent the motor from burning up. If you add too many items, it will load down the agitator. this is usually normal operation. If you are sure that it is slipping more than normal, the clutch mechanism might be failing.
Sep 02, 2015 | Washing Machines
Agitator seems to slip and not constantly move during wash cycle
no it is not suppose to slip it sounds like the agitator dogs need replacing it is quiet easy to repair and not expensive it only cost me $8 and took twenty minutes to do when I replaced the ones on my washer
Dec 28, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Hi, I have a Kenmore Washer Model:110.24722300 70 Series. The agitator is slipping how can i fix this problem and what parts do I need.
Agitator Repair Kit
Item #2744 (OEM Part)
$19.85
Washing machine agitator repair kit with a medium length cam (there are other kits available for different models). This kit should be used when the top part of the agitator is not moving properly but the bottom part is.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285811/2744?modelNumber=110.24722300
Oct 19, 2012 | Kenmore 22422 Top Load Washer
LG Top load fuzzy logic washing machine only washes small loads
Please check if the drive belt to the main motor to the agitator is slipping or is loose. It is also possible that the agitator is jammed and so could have friction so that the belt slips.
Aug 17, 2012 | Whirlpool Washing Machines
AGITATOR SEEM TO BE SLIPPING, NOT ENGAGING COMPLETELY THROUGHOUT THE ENTIRE WASH CYCLE.
The agitator has under the cap what are called agitator dogs. They wear out causing agitator to slip. They sell a kit at appliancepartspros.com cost $10. Easy to replace comes with instructions.
Aug 18, 2010 | Whirlpool LSN1000LW Top Load Washer
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Eric
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Agitator slipping
is it a top load washer?if so there are 4 dog ears under the agitator cap that turn it ,you need to replace them($2 at your local appliance parts store-mike
Mar 19, 2009 | Kenmore Washing Machines
I have a different model, but my agitator came off with brute force. I used 2 allen wrenches in the slots on the side of the agitator to get leverage and then yanked until it came off. The problem is your air bell coupler.
Jan 30, 2009 | GE WJRR4170E Top Load Washer
Agitator slipping
change your agitator dogs in agitator
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
