Question about Saeco Magic De Luxe Espresso Machine
Can't get to the main switch
There is no power to the machine there is a sound that comes out of the main switch on the lower side but I don't know how to get in to test the switch to replace it. I an electrician
    President:
  • 1,618 Answers
Remove the screws in the grinder chamber, also the screws under the water tank,remove the steam knob, open the door and there will be 2 screws holding the top panel in the machine.
Posted on Jun 02, 2009
I have power but my treadmill won't move
Sorry to hear you're having that problem with your machine, some basic checks you can do for you treadmill are as follows.
Before turning your machine off and removing the main shroud,
Verify you are using a dedicated circuit (wall outlet) and verify that power coming in to make sure your on and off switch is working.
Remove the main shroud and turn off machine.
Check the main cable from the console to the lower control board and verify it is secured properly into the board.
Check all connections to the lower control board by pressing them in to make sure they are secured into the board.
Make sure to visually inspect the lower control board to see that the boards LED's are lighting up appropriately with power coming to the machine.
Check any fuses on the board and any visual burn marks to any components as this indicates a short in the board.
If you find that after doing these basic checks you need any further assistance please do not hesitate to call our Technical Support Team at 888-713-2880 or visit us online at www.sportsmith.net
Jul 14, 2015 | Exercise & Fitness
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Lafeyette LR-5000 has a loud hum after it come on in all 4 channels and the volume is all the way down it was working fine I don't know if in the preamp sec or power supply I want to know where to...
This sounds like the mains hum getting in. The cause is always the large electrolytic capacitors in the power supply. Replace all of them to be on the safe side.
Jun 30, 2013 | Audio Players & Recorders
I just purchased a 2006 Navigator and the button to lower the rear seats, does not work. I don't have manual yet, and don't know how to check the fuses, or if this is even the problem...
locate the fuse box under driver side instrument panel,use a test light hook clip to ground and probe each side of each fuse test light should light when you touch or probe top both side of fuse test light should light.if one side dont light fuse blowed both sides light fuse good.also use test light see if power at the switch if yes problem in the seat motor lower mechanism.
Sep 01, 2012 | 2006 Lincoln Navigator
WorkCentre M20i will not power on
Most likely on this machine the Low voltage power supply is out.
Before ordering parts, check the back of the power supply to make sure the connectors, 110 volt on the back of the plug have not slipped off. Sometimes they are not slipped on the connector very good and come off. Also, make sure the switch is good, sometimes these switches are just mechanically bad inside.
Disconnect the power and disconnect the main motor plugs, power back on the machine and see if the machine at least comes on, even with an error messege on the console. Sometimes a bad main motor will cause the main board to drain power.
Also, make sure before ordering this power supply, the correct part is ordered for this model machine.
Let us know what you find, just becareful with the power plug in the machine when working in the electrical circuits. Unplug the copier when needed.
Oct 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Error code sc548
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps.
Jul 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Washer keeps stopping and flashes e20
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 23, 2009 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
RESETER
THIS MACHINE SHOULD HAVE 2 ON SWITCHES. ONE ON THE UPPER RIGHT WHICH ONLY TURNS THE LIGHTS OFF TO THE CONTROL PANEL.ON THE LOWER LEFT SIDE THERE SHOULD BE A RED SWITCH THAT IS THE MAIN POWER SWITCH.THE RED SWITCH IS THE ONE THAT RESETS CODES.
Oct 24, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Saeco Magic De Luxe Espresso Machine Logo
42 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
