Question about Garden
Cannot seem to change nozzles from basic to soap nozzle
How do you change the nozzles on the 2600 Husky Pressure Washer?
4 Suggested Answers
SOURCE: Not getting any pressure at nozzle.
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
Posted on Sep 08, 2009
heatman101
  • 43501 Answers
SOURCE: Water is exiting the washer through the soap tank
The check valve in the hose from the soap tank is bad or has dirt in it...this allows the water to back through the hose into the tank. Replace the check valve and all will be well again...
heatman101
Posted on Jul 05, 2011
mxc2
  • 146 Answers
SOURCE: I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Posted on Mar 30, 2012
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Will not siphon
This model pressure washer will only siphon from the soap dispenser when you have the low-pressure nozzle attached and then will only sort of dribble out the suds. Good for sudsing, but no good for cleaning. You'll have to suds 1st then change to a highwe pressure spray nozzle to perform the actual cleaning. If it won't siphon with the low pressure nozzle either, then check for a blockage (old, dried soap) in the suction line tubing. Hope this helps!!
Oct 19, 2014 | Dewalt Pressure Washer. 3000 PSI 2.5 GPM...
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Honda gcv160 wont dispence detergent
it will not draw soap while using pressure take out the nozzle or use the large black nozzle
Jun 09, 2012 | Craftsman 2600 PSI Honda Powered Pressure...
Mar 29, 2012 | Garden
Husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Oct 07, 2009 | Garden
Pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Huskey pressure washer 2600 the water works but not the soap dispenser
Hello kjc33;
Do you know that the unit must be on low pressure to apply soap. The control is usually on the nozzle
Jul 11, 2009 | Garden
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
