Question about Symbol P370 Handheld
Symblo Scanner not pairing with Base
I have a symbol P470 but it won't read the barcode on base and pair. I down loaded some barcodes for programming but it still will not read anything I printed. HELP... I'm using windows XP.
  • 31 Answers
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Posted on Jun 30, 2009
How i can connect my p370/p470 barcode scanner with my window xp system from where i download the driver and software for this..??
please help me?
Posted on Jun 23, 2011
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Oct 21, 2013 | Honeywell 2020-5B Cordless Bar Code...
Three of the 4 scanners we own are all flashing blue and white and make double razzberry tones when scanning. What's happened?
they've lost their connection to the base. put them in the base, unplug them and plug them back in to let them pair up again.
Sep 30, 2011 | Metrologic Instruments MS9535 VoyagerBT...
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
I use usb base ls2208 my problem is every time
Hi, to make the scanner automatically hit enter print and scan the barcodes Scan Options, Data Suffix, and Enter from Adobe pages 222 and 223 of 342 of the LS2208 Product Reference Guide.
Jan 06, 2010 | Symbol LS2208 Handheld
No data is transmitted
you need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
Jul 01, 2008 | Symbol LS 4071 Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Symbol P370 Handheld Logo
1,777 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
