Question about Whirlpool LER5636P Electric Dryer
LER4634EQ1/Won't turn on
I was turning my dryer on and it started for a couple of seconds but the dryer shut right off. It will not come back on. any tips on what to do?
    Scholar:
  • 85 Answers
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on Jun 01, 2009
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Dryer Model # LER4634EQ1 As the drum turn's the
What the most probable things thats causing that noise is the rear drum support rollers.
This youtube video will show ya how to take apart the dryer and replace those rollers
http://www.youtube.com/watch?v=wBf_vwvlFGM
The part number for the rollers is 349241T that part number is a kit for both of the rollers in one kit plus the plastic triangle clips that hold them to the shaft they fit on.
That part can be purchased at your local appliance parts store or also online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 12, 2011 | Whirlpool Dryers
I'm pressing the start button but the dryer won't start. it just beeps about 3 times then stops. The first time i tried it it ran for about 5 secs then shut off.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My dryer shut off in the middle of a cycle and now won't turn back on. What could be wrong with it? I have checked all my breakers so its not a problem with my electric.
heatman101
Aug 19, 2011 | Kenmore Dryers
Maytag epic Z dryer. I hear rapid beeps when I press the start button and it won't start, no matter what setting I try. The door is firmly shut and the lint tray is clean.
heatman101
May 20, 2011 | Dryers
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
KNOBS WON T STOP TURNING, THEY WON T START DRYER
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 30, 2010 | GE DRSR483GD Gas Dryer
Drier shuts down after several minutes, the fan and vent are free of lint. It will start right back up and run several minutes.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | General Electric DHDSR46EGWW Dryer
Whilpool Dryer Won't Run
you have a bad saftey swith inside te dryer this cost anyware for $8.00 to $ 15.00 for the part
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
158 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
