1999 Pontiac Sunfire Logo
Posted on Jun 01, 2009
Light on by fuel gauge (arrow shape going downward) 1999 sunfire pontiac
Light on by fuel gauge (arrow shape going downward) 1999 pontiac sunfire
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
334
Points
Check your engine coolant.
Location of fuel pressure test valve on 1999 Sunfire
ECOTEC engine?? must use in line gauge to test
2answers
I have a 1999 Pontiac Sunfire with a 2.2L motor. It runs great considering how old it is. Last week I started it up and several of my dash lights stayed on. They are: The oil light, the battery...
Sounds to be the dash itself. there is a chip in there and it sounds like it shorted out. You have to replace the panel. Junk yard would be best and cheapest.
1helpful
Fuel gauge doesn't work 1999 pontiac sunfire
check fuses,remove sender unit from tank,connect ohm meter to it and physically move arm up and down slowly and check for increase/decrease in resistance,if this is ok then supply power to the wiring to gauge and see if the needle rises,if no change in resistance sender is rooted,if no change in gauge when it is supplied power then the gauge is rooted,when diagnosing electrical probs always check fuses firstelectrical
2helpful
Gas gauge does not work - 1999 Pontiac Sunfire
One of two problems, your fuel level sending unit is defective, or your gauge Is bad.
1helpful
2answers
99 Pontiac Sunfire
Hello mcammdf.
To properly test the fuel gauge circuit you will need to check the purple wire at the connector to the fuel tank.
Run a wire from the purple wire at the connector to body ground. If the gauge moves when you ground it the circuit to that point is good.
These cars are noted for fuel gauge problems and most probably the issue will be the sending unit in the fuel tank.
KL
2answers
I don't know what the symbol means on my 1999 Pontiac Sunfire
does it look like a radiator? Low coolant sensor, may be in the overflow tank. Check your coolant levels when cold.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
