SOURCE: Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
SOURCE: yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
