Question about Dometic Rooftop RV Air Conditioner
My Coleman RV roof air went off and will not turn on after if restored breakers.
I have a Coleman AC on roof of travel trailer. I plugged in 110 current and then turned it on. AC ran for about 10 seconds and them cut off. I cannot restart it? I have refreshed the main RV circuit breakers.
  • lshelton116 Jun 02, 2009
    Thanks. I'm at work, but will check tonite. It is connected to power. It has worked before. I need to use bigger extension cord and plug into 30 amp. That may be problem. Where is a fuse in the unit? I have cover off, but have not opened inside boxes.
    lshelton116
    micromaster:
    I thought when you mentioned the cord size and length that you were right. I plugged a 14/3 cord into 30 amp plug, and the AC took off like new! Thanks a bunch.
    lshelton116
    Brigadier General:
  • 3,614 Answers
did you check if the unit still have the power, have you check the electrical wiring and the plug. also check the unit fuse for any problem
Posted on Jun 02, 2009
  • micromaster
    micromaster Jun 02, 2009
    it is located near the or int the powersupply board area.
    update me again
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Coleman RV Roof Type 110v
GO TO rvcomfort.com
Jul 25, 2010 | Coleman Heating & Cooling
Colman unit is getting no power
GO TO rvcomfort.com
Sep 10, 2009 | Coleman Mach III Air Conditioner
Drain for a colelam rv air conditioer
It is entirely possible that a five minute test would not produce any noticeable amount of water. Turn off everything in the house that is using electricity and your 20 AMP service will be sufficient to run your AC.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Coleman roof a/c units compressor not coming on
GO TO
www.rvcomfort.com
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
256 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
