Question about Whirlpool LER5636P Electric Dryer
Estate dryer wont engage
Dryer wont engage when i press the start button I press the start button and nothing happens. I turned it on and it started for a second and then just stopped. Now it doesn't do anything.
  • natswish Jun 02, 2009
    Thanks! We think it is one of the thermostats. We found one that looks burned out.
  • 6,784 Answers
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Posted on Jun 01, 2009
  • Michael Masters
    Michael Masters Jun 01, 2009
    If all the above checks out OK, replace the start switch.
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
My dryer is an estate model #eed440sq0 and when you hit the start button nothing happens.I tried putting it in a different cycle but still nothing could it be a faulty lid switch?
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Estate EGD4400SQ Gas Dryer
Sounds like it maybe the door switch.
Apr 27, 2009 | Whirlpool LER5636P Electric Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Dryer won't stay running
the centrifical switch on the main motor is not engageing you can take the dryer apart and clean it its on the motor shaft where the pully is but some times you have to replace the motor if the run windings are bad
Jun 17, 2008 | Estate TEDX640JQ Electric Dryer
Estate electric dryer
hi thanks for the question i looked it up and the most likely cause for this problem is the thermal fuse located at the back of the dryer remove back panel and on the air duct you will see a small plastic piece with 2 small blue wires going to it replace this part but also clean all venting to the outside as this will cause this to happen the appliance doc
Nov 28, 2007 | Estate TEDS740JQ Electric Dryer
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
172 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
