Question about Maytag PTB2154G Top Freezer Refrigerator
What to do next--the freezer hasn't been sealed for a day
If I close it now will it re-freeze the contents, or must I remove everything and defrost? The outside walls of the freezer are warm; there is some water on the floor (not much); the condensation has "refrozen" in puddles on the shelves, and the coils are frosted with ice. How can I tell if it's working again when I close the door right now? Please send details about what to do next. Thanks!
    Problem Solver:
  • 16 Answers
Unit might need cleaning under and in back of fridge (dust bunnies) use vacuum. front bottom louver panel has 2 screws or is snap fit. only other thing it might be is defrost timer
Posted on Jun 02, 2009
Fridge and freezer not getting cold enough. Alarm going off every day.
The two main causes are.
The defrost timer failed.
Loss of refrigerant due to a leak.
Less common, door seal failure.
First put a piece of paper in the door seal area, close the door.
Can you pull the paper out without effort??
Yes, check the door seal.
It probably needs replacing.
Is the freezer coil freezing?
Yes, check the defrost timer.
It has probably failed and needs replacing.
Jul 27, 2015 | Refrigerators
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool AFB126/H/AL Freezer - Defrosting & Refrosting
Hi. I am Kelly and welcome to FixYa. Here is the real question..... Is the food staying frozen?
Freezers usually defrost 3 times a day (8 hr intervals) Some as often as 4 times a day. The freezer use concept is that it is not opened more than 3 times a day. (Yes there will be more times than that any given week)
Having said all of that.... some things to look at.
1. Check the door seal for any signs of tears... grease... collapse...
2. Make sure there are no gaps in the door or between the closed door and the seal.
3. Many people don't check this one... but make sure it is level. An un-level freezer can cause the door seal not to function correctly.
Now if your saying that the food is actually defrosting... then there are a few other things that can cause that.
A. Sticking / defective Defrost timer
B. Defrost element is not heating and the freezer goes through a VERY long defrost cycle as the contents have to reach 60 Deg F for the 60 Deg bi-metal thermostat to close and advance the defrost timer to start the compressor.
C. Intermittent operation of the 60 Deg thermostat
I hope this clears things up a bit for you.
Thanks for using FixYa.
Kelly
Feb 10, 2010 | Freezers
The freezer makes ice and keeps everything frozen, but does not defrost. we are getting a very fine frost on everything including the top of the freezer compartment. What is wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
The other cause and type of frosting is automatic defrost failure.
Jan 02, 2010 | Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Everything in the freeze has a thick layer of ice
Typically, this is an indication that the seal on the door needs to be either cleaner or replaced. begin by cleaning it thoroughly, also clean the frame of the door. Then defrost the ice using a blow dryer and dry it. Then over the next few days you will know if it is the seal if the ice forms again.
Dec 05, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Freezer defrosts and unfreezes everything. A day or so later it refreezes.
most domestic freezers do not have a defrost control. .90 percent of them freeze and every few years enough ice builds up that you have to unload and manually defrost them. so what is probably happening is the stat is sticking in hte off position and not recognizing the call for cool when the temp gets up. if you catch it off and thawed try tapping the stat gently after the temp is getting way warm. if the box comes on and starts freezing again then the stat is sticking in the off cycle and needs to be replaced. usually under 75 dollars and fairly easy. two wires connect in any order.the stat itself has no in and out requirements. power in and power out when it closes. there may be a ground wire usually green and smaller connector attached to some newer stats. look close and you can see the difference. usually the voltage connections are next to each other and the ground is off to the side or end. stat is usually behind a plastic cover inside the freezer. good luck, disconnect power when you change stat of course.
Nov 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Whirlpool model ED25TW intermittent freezing
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Oct 15, 2008 | Whirlpool Refrigerators
Maytag PTB2154G Top Freezer Refrigerator Logo
54 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
