Question about Homelite Garden
Will not stay running .
I must go between choke and half throttle to keep running,will not run on full throttle stalls out.
  • Anonymous Mar 15, 2014
    starts and runs with throttle on but then stalls
  • 1,040 Answers
You need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. If you need tip on how best to do this, just let me know. If after you have reassembled and tried to start, and it still does the same thing, you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 02, 2009
  • Jim Parker
    Jim Parker Jun 02, 2009
    My comment was meant to be the solution. Sorry
    Jim
  • Jim Parker
    Jim Parker Jun 04, 2009
    Thanks for the rating. If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools-Building & Power-Hand Tools" at FixYa.co
    Thanks Again,
    Jim
Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Stalls out at full throttle
Has the air filter been removed, damaged, or the airbox not seated propelry on the carbs neck, this would cause it to run lean hence requiring the choke to be in operation all the time. Have you tried fresh fuel?? This goes stale after a while. I hope this is helpful, Ian
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
The saw wont stay running. I start it with full choke and throttle but when I try to close the choke it just dies. I can get it to start with half choke, but again it will die when the choke is off. The...
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Jun 14, 2009 | McCulloch Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Garden Logo
164 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
