Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Still cannot recieve any channels from auto channel select.
All other t.v's in my household have full channels except my rca.
5 Suggested Answers
  • 319 Answers
SOURCE: model rca r52wh74yx50
Consult owners manual for channel programming. Channel program sequence may be interrupted by weak or drop out of chl 11 signal. This happens occasionally when signal is from standard antenna
Posted on Apr 23, 2008
ladywinn
  • 5138 Answers
SOURCE: Won't recieve digital channels
I have the same type of TV and as soon as i figure out why it also, will not convert from analog to digital ,I can hook up to converter box get all kind of clear channels I am quickly finding out These Sets Are either minor problems or very major problems. They have over 32 different SSB tuner boards,and they all look alike but are not, hookups and connectors are not the same.
Posted on Apr 08, 2009
Slinteriors
  • 8617 Answers
SOURCE: auto channel select not picking up all channels it should be.
You need the signal board. You can get one at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 01, 2009
  • 1030 Answers
SOURCE: i try to do auto
try this.... go into setup and make sure that analog tuning is selected... you could possible only have digital selected
Posted on Apr 29, 2011
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
I can not program the tv with the cable, which input goes with the cable channel. I have a 32 inch RCA with SRS . HELP
I do not see a question. "Which input goes with the cable channel?" Don't understand. Is there a cable box or SAT box connected to the TV? What kind of cable is running to the TV from the source? If you just have the coax cable going from the wall to the TV, then you need to auto format the channels. Select menu on the TV remote. Find Sources or Cable. Select "Cable" not "Air". Select Auto Format. May take several minutes. Input selector from TV remote should be "TV".
Jun 30, 2010 | RCA Televison & Video
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Universal remote
Consult VCR operator manual .....If I remember,there is a selection in the menu to designate a channel so that when a source box is used, the channel selected remains the same in
timer mode........channel recorded is selected on box,in that
equipment configuration............so step thru the video recorder
menu on page at a time.........T.
Dec 18, 2007 | RCA Universal Remote Control
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
