Question about LG 50PX4DR 50 in. Plasma TV
Crackling Sound from Speakers
I just bought my  LG 50 inch and there is a crackling noise coming from the speakers. If I mute the sound then the crackling goes away. This just started the second day i had it.
  • Anonymous Mar 24, 2014
    crackling
  • 92 Answers
Check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Posted on Oct 31, 2007
  • Dennis Gore Jul 08, 2013
    this is not a crakle and can still hear voices and music, this is a steady static type sound
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Crackling noise from subwoofer!
If ayou have a system with speakers that works and a different set is crackling
the set that crackles is to be determined the bad set. Cones dry up a bad assembley just coinsidents having a bad set of speakers. It is an AUDIO problem not a computer problem
Jul 27, 2009 | Acer 90.00012.30B Computer Speakers
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Dec 08, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
LG 50PX4DR 50 in. Plasma TV Logo
1,614 people viewed this question
