Question about HP Pavilion DV5-1000US Laptop
Overheat and switches off automatically
My hp dv 5 overheat and switches off automatically.
  • fnkoka Jun 01, 2009
    i dont know how i should check to know that the fan is working
  • Rik Evans May 11, 2010
    Is the fan working?
  • 674 Answers
Check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Posted on Jun 01, 2009
Thermo overload switch keeps tripping
Your pressure switch that shuts off the motor isn't working causing the motor to overheat. If you think the pressure switch is ok then the motor may have a shorted winding inside.
Oct 01, 2014 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Why does my 1994 kia sehia overheat when i am driving but not when its parked?
may need belt tensioner, this happend to me, needed belt tensioner, or intake manifold gasket. i finaly got my cooling system under control w all u did and this, too!
Aug 28, 2012 | 1994 Kia Sephia
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Smoke coming from reset button
Once the electric circuit starts smoking, then that says overheat and short circuit. The motor coil is overheated and will never come back to life.
I wrote ez replacement step from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jan 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My pc is getting automatically switched off i checked my smps and its working fine.i got intel i3 processor and mother board DT55C
Intel makes so many claims that their processors won't overheat, but they do overheat. If yours is fan cooled, then check the fan, you may just need to replace it. if it's liquid cooled, check that. I don't know much about liquid cooled. I hope this helps.
Nov 28, 2010 | Intel Motherboard
My dv 5 gets so hot!
I have a HP Pavillion DV5 aswell. Your laptop is overheating, because something is getting in it's Fans. If you don't use a desk or cover the fans it will overheat. But your laptop is heating to a point where i think it's defective. Go see a computer technition and see what he thinks. My DV5 never heats up, so i'm almost sertain there is something defective. Goodluck.
Jun 09, 2009 | HP Computers & Internet
Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
May 28, 2009 | Optoma EP721 Projector
Transmission oil in coolant?
Trans fluid can get into radiator by the trans cooler built into radiator side, automatics...
Engine oil can come thru cracked block, head gaskets
Which oil is it? Either way it needs to be fixed.
Typically with automatic trans they can overheat and cause engine temp issues, because they cool thru the radiator using an in tank cooler along side.
IF you overheat the trans you CAN overheat engine
IF you overheat the engine you CAN overheat the trans
Jul 17, 2008 | 2001 Chrysler Town & Country
HP Pavilion DV5-1000US Laptop Logo
733 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
