Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
NO INTERNET CONNECTION
WE ARE NOT ABLE TO GET ANY INTERNET CONNECTION IT IS SAYING LOMITED OR NO CONNECTIVITY.BUT YET PLUGGING A COMPUTER DIRECTLY INTO ROUTER YOU GET CONNECTION i need dns codes for the new black surfboard motorola modem
    Genius:
  • 1,268 Answers
You need to properly configure the wireless settings of your computer. Make sure to disable the firewall on your computer like windows firewall or any other firewall. Now make sure that you have entered the correct wireless security key on your wireless settings. Go to control panel > network connections > right click wireless network connections > properties. Go to Wireless Networks tab and remove all the Preferred Networks there. Go to Add and proceed to adding manually your wireless settings.
Posted on Jun 02, 2009
Internet pppoe
Check with your ISP to ensure you have the correct PPPoE details. If your router has a built-in "ping" feature, try to ping a website and see if that works.
Check on your computer to see what IP address it has, and if it's been "assigned by DHCP" or not - if it has, then it should communicate with your router. If not, then there's an issue with your PC and router communicating together.
Let me know how you get on, and I'll help further.
Oct 29, 2013 | Trendnet Wireless Home Router TEW651BR
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Safari can not open the page because the address is invalid
This problem is either the unit is losing connectivity to the internet or the web address is being typed wrong. Losing connectivity could be caused by a number of issues, including viruses (yes, an Ipod CAN get a virus as can anything that connects to the internet).
If you are sure your internet connection is good becuase you can go to other websites, try plugging the Ipod into a computer with ITunes and doing a system update. That should resolve any issues.
Mar 18, 2012 | Apple iPod touch
My wireless is not connecting to my computer its saying UNIDENTIFIED NETWORK ACCESS LIMITED CONNECTIVITY
You may be connected to the router, but the router may not be properly connected to the internet. You could try unplugging the router's power for 15 seconds, then plugging power back in. Also, try making sure all the cables in the back of the router are plugged in properly. The last thing you could try is restarting your actual modem. This is the device that actually connects to the internet, and it sounds like you're having internet connectivity issues. So the problem may be there.
Sep 12, 2011 | NetGear WGR614 Wireless Router
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Cable connectivity
hi pat seems your router is not configure yet for internet connection, for cable connection you must log into the setup page of the router and clone the mac address of your computer.
to do that you can call 1-877-453-5465
to have someone walk you trough the steps.
flashing lights simply means activity on your network, and you get activity when you have internet connection.
hope that helps pat.
Oct 06, 2008 | D-Link 802.11g Wireless Router WBR-1310...
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Dec 19, 2007 | Computers & Internet
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
274 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
