Question about Coleman Pressure Washer PW0881800
Coleman 1210 power washer no water comes out of gun
I know this is very old but worked last year. now when i hook it up i can't get it to wash. took off hose and air blew it, water goes thru hose and also machine. no water or air when i blew it thru gun.
  • khickman012
    khickman012 Jan 06, 2013
    Hi my dad has never used his pressurewasher and doesn't know how to use it, what plugs into what, pictures would be great
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
Posted on Jan 06, 2013
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
Power washer starts, water to washer on but no water pressure come out the hose
this with the engine running? If so there eigther is a restriction in the main water feed or the pump is damaged or possibly needs to be rebuilt. Did you know you can never start the mechine with the water hooked up and on full and you should trigger the gun to force the air from the water pump before you ever start the engine. Is it a mi-t-m pump or a cat pump. The mi-t-m pumps have a problem with the plastic cages that hold the valves braking and getting stuck between the valve and the valve seat if you take the caps off the pump you can pull the peice out and the mechine will work again. The cat pumps have cremic pistion and if over heater need to be rebuilt but is a vastly better pump and if maintained wil last 25 to 30 years under heavy use
Dec 07, 2010 | Briggs & Stratton Power Products 1539...
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
My Honda GCV160 Pressure washer runs great, but isn't creating any pressure out of the nozzle. Not even a drop out of the wand. Its been on hiatus while I've been recovering from an injury for 3mos. It...
Take hose and gun off pump.
Start engine.
See if pressure comes out of pump.
Next, remove water hose and look at filter washer.
Clean or replace filter washer.
Turn on water and it should come out of pump on other side.
These steps will tell you if problem is water supply or pump.
Sometimes the problems happen because the gun lever is bad.
Hook up hose but not the gun
See if pressure comes out hous.
These steps will tell you if problem is gun or hose.
Oct 25, 2010 | Honda Garden
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Hook up water and turn on water.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
MY HONDA POWER WASHER
Nozzle is dirty. Use small diameter wire to clean out nozzle.
Sep 09, 2009 | Honda Pressure Washer PSI 3000
I have a Coleman 2750 power washer that just idels when you pull the handle. Why is it not reving up with pressure?
Possibly has leaking seals or there is a blockage in the gun or hose. remove the hose first and see if it is putting out enough water.
Jul 31, 2009 | Coleman Pressure Washer PW0881800
20 year old washing machine leaks
the tank is hooked to the pump and the pump to the drain hose, by flexible rubber couplings.
Try those couplings to see if they have deteriorated, they are cheaper to replace than to buy a new washer ort get a service man
Jul 27, 2008 | Washing Machines
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Coleman Pressure Washer PW0881800 Logo
1,043 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
