I'm also having trouble re-installing the
SOURCE: Warm to Hot molding that seals the doors
Either the fan motor has gone bad or the coils under the fridge are too dirty. Both will cause a no cool situation and cause this area to become too hot. Part of the coil runs thru the cabinet in this area to prevent sweating. This is a good indication of dirty coils or a bad/weak fan motor. If your fan was noisy I would replace it before it goes out completely. This excessive heat will lead to premature compressor failure.
SOURCE: Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
SOURCE: my refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
SOURCE: double doors at different heights how do i adjust
remove the kick plate on both ends of the fridge ther are two bolts adjust the right bolt
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
