Question about Microsoft Age of Empires: Gold Edition for Windows
Game installs 100% ,starts updating system files, wont finish.
Opened program files,and started the game intro,played through to the play menu . I selected single player mode, and it tells me there is no disk in drive.
    Problem Solver:
  • 17 Answers
You need to keep the Age of Empires install disk (usually labeled "Play Disk" or is just Disk 1 in older games) in your disk drive while you play the game.
Posted on Jun 02, 2009
FSX installed and activated easily (3 times) but no icon on desktop nor entry in "all programs" or MS Games. FSX plays after activation until I close program. Then cant be found.Can you help?
try to search it at program files. maybe at installation start menu folder or desktop icon didn't created but the program already installed.
open 'add or remove programs' window. if your game are listed in there, then your game is already installed at the computer. open C drive (where is windows installed) go to program files folder and search your game folder. if you find it then search the game application (.exe) right click and 'send to desktop'.
if your game is not listed in 'add or remove programs', then u need to reinstall the game. maybe there is problem with your VGA or RAM that makes the game erased after you playing the game. or maybe u have your computer 'deep freeze' program and you installed the game at frozen condition.
hope this useful.
Feb 18, 2011 | Microsoft Flight Simulator X
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
I can not play game in my laptop.when i open the game it says can not connect to d3d device.check directx.what will i do?
Hi!
Microsoft DirectX is a software for handling multimedia task, video and game programing. You can download DirectX compatible for the operating system that you use in your laptop.
here are the list, select the file suited for your operating system, click it and save to start downloading, once finished, install it on your computer.
1. DirectX10 - windows vista sp1 & sp2
2. DirectX 9.0c - windows xp sp2
After installing the right directX for your operating system, try to play the game and direct 3d settings will work..
Please rate if this solution work...thanks..
May 27, 2010 | ASUS P5V800-MX Motherboard
Wont play when i insert disks only the games on there
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
My pc has create a problem that has problem when i start game i
If you would have listed the model & manufacture of your graphics card or if the graphics card is built into the board the (Model number of the motherboard)
Or if the graphics card has been added to your system, (The name of card & model number).
Finding an answer for your problem would go a bit faster & be more accurate.
If your graphics card is built into your motherboard or if the graphics card is installed into an AGP/PCI or PCI-E port, you'll need to uninstall your graphics driver software. The error message you posted; (Your display driver created a problem). One or more driver files are most likely corrupt.
To correct this you will need to open windows control panel. Than open the icon, Add/Remove programs. Find your graphics driver software & uninstall it. After which windows will want to restart.
(Do so). When windows finishes loading re-install the driver software for your graphics card. (Your graphics driver software should be on a CD).
Than restart windows, even if windows does not ask you too. When windows finishes loading again. Load windows update service. Click the start button, slide your mouse to All Programs, than slide to & click on Windows update. Install any updates windows finds.
(Do not install windows explorer version 8.0) Too many bugs in version 8.0.
While on windows update site look to the left. If you see that windows also has hardware updates, include these in the update process. (Restart your system when downloading is finished or if windows request it).
Lastly, before you try playing a game download & run this free program named RegCure. (This program will clean your system from left over junk& non needed files).
Click on the link below to download RegCure;
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
If you still receive en error message or if your game locks up/ freezes, provide the information I mentioned above so I can better help find a fix.
Cheers!
Thanks for using FixYa!
Mike
Jun 02, 2009 | Computers & Internet
CAN NOT PLAY GAMES
I would start by upgrading the video card, because it is most likely the problem. Also try lowering the quality settings within the games themselves to increase performance. RAM also plays a factor in games, these days 2GB of RAM and up is ideal for gaming.
May 06, 2009 | Intel Motherboard
Problem with FSX Demo setup
You need to find the directory where it has installed, usually in C:\program files\Microsoft games\FSX and then locate the .exe file. Right-click the mouse over this icon, holding the right button down, drag the icaon onto the desktop, release the mouse button and when teh small menu appears choose "create shortcut here" option.
Then you can start the program using the new icon on your desktop. As for playing it, you need to read the manual as it would take too long here to explain it. Good luck
May 03, 2009 | Microsoft Flight Simulator X for Windows
Movies play/games will not!
if its less than one year and under warranty your best bet is to call Sony and get it replaced/repaired..i had the same problem and had to get the bluray mech replaced {no service in India :( }
hope it helps!regards!
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
PC IS NOT RUNNING ANY CD/DVD'S
okay try this
Go to your My computer icon--right click on it
properties-->hardware-->device manager
Find ur cd/dvd drive on it
Uninstall it by right clicking it (dont get scared ur system will detect it itself in next reboot and u dont need any drivers for it)
hope it will works if there is no physical damage
Please Rate ...
Sep 26, 2008 | Computers & Internet
Microsoft Age of Empires: Gold Edition for Windows Logo
343 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
