Question about Samsung HP-T4264 42 in. Plasma HDTV
My tv keeps resetting
Even if i unplug for 5min an then plug it back in it will work for a while but sooner or later it will start resetting again which is not cool how can i solve this issue i have updated the firmware but still problem is not resolved.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
WE WERE WATCHING TV AND IT JUST TURNED OFF BY ITS SELF. WE UNPLUGGED ALL CORDS IN BACK FOR A FEW MINUTES AND IT STILL WONT GO BACK ON. THE RED LIGHT ON THE BOTTOM WONT EVEN GO ON. PLEASE HELP. THIS NEVER...
Tries tv unplug,replug it back like about an hour later.Tv now will be resetting itself back to the factory setting.Now the tv should be working again.If still have the same result than the tv power supply board is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2011 | Televison & Video
Tv won't come on. Red Light keeps blinking.
Tries tv unplug,replug it back like about an hour later.Now the tv is resetting back to the factory setting.The tv now should be working again.If it have the same result.Mean ur tv power supply board have a problems and it is the causes.That the board,where the power a/c coard plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Jan 15, 2011 | Pioneer Elite PRO-950HD 42 in. Plasma...
Have sony kdl40ex400, tried initial setup to cable, must have done something wrong, can only get channel 4, even when not going thru cable box
Tries tv and the cable box unplug,replug it back like an hour later.The tv now resetting it self back to the factory setting.The cable box it resetting and upgrading it softwares.Now plug the tv back through the cable box again.Now go into ur tv menu select Cable and scan for Cable channels again.Now u should have all ur pay cables channels now.
Nov 17, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Turned off
Greetings!
You have said that your TV is new, therefore it is underwarranty. Better not to remove or touch any parts of your TV that will cause more damage. Bring it to the center for check-up.
Thanks
Nov 05, 2008 | Sylvania 6727DF TV
Television
scanning the channels would not have done damage, the tv probably just sensed the unplugging of the power as a ''spike'' in the power line. Just let it sit unplugged for a while and then plug it back in, should turn back on again. also, if you are on cable or such, the scanning of the channels should actually be done, in ordr to see all available channels when the vcr is not in use, or if not, just set it to channel 3 or 4 to see it through the cable box. ps.. In the future, don't buy tv/vcr / dvd comos, the main reason why most peole buy those things is so the kids will leave the bigger tv set alone, problem with that is- kids will be kids, and sooner than later they will stick something the player's slot and screw the unit up- that leaves the tv by itself, which they will not want to see if the player is not working. so you are out of both and the kids are back taking the bigger tv away from you. best thing is always to buy separate units (vcr/dvd player combo's or separate units are usually cheaper to buy separately along with a dedicated tv than one of those all in one units. something goes wrong, just fix or buy a replacement for the system. and you get to keep your own tv.
Jun 12, 2007 | Sharp 35VX-H2000 35 in. TV/VCR Combo
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Samsung HP-T4264 42 in. Plasma HDTV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
