Question about Edirol UA-25 External Sound System
Cannot record In windows XP, control panel, audio devices, voice: playback is OK, but recording has no active volume control (greyed out). Test Hardware button goes through process but cannot find signal. Of course I have selected Edirol UA25 in all cases as the input/output and all controls on the UA25 are set at reasonable levels/positions. My edirol UA-25 is installed...i want to record on mixcraft but when i select the edirol as the recording device, it doesnt record. it doesnt even show the audio levels.
2 Suggested Answers
SOURCE: cannot record
Buy another product.
Posted on Jun 28, 2007
Is there supposed to be a special driver for this Labtech microphone? I am running XP and have all the volume controls active but it is not recording.
In addition to the instructions below you may need to make sure you have selected the right sound source (normally WAVE) in your recording program
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 25, 2011 | Labtec Microphone Microphone
DOES NOT RECORD ANYTHING ON MY WINDOWS XP
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Click VOICE
That should be it.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
Hy, I have a problem with my mic that is all ready instaled in my laptop also with a camera. When I go to the Control panel to see what is the problem, everything there is ok, but I am not able to work...
There are two separate mic settings in control panel - record and playback. Have you enable record also? See below. Also in Skype-Tools-Options check you have got the right audio device selected (normally WAVE)
Click VOICE
That should be it.
Feb 22, 2011 | Toshiba (P000257700) Microphone
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Click VOICE
That should be it.
Feb 21, 2011 | Audio Players & Recorders
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
My microphone on my laptop does not work i checked everything test it nd cnt hear my voice..?
Click VOICE
That should be it.
Feb 16, 2011 | Toshiba (P000257700) Microphone
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
387 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Iqbal Husain
Iqbal Husain
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
