Question about Crosley CAWC529JQ Top Load Washer
Won't stop filling up with water
Been gone on vacation for 11 days when returned i started to do laundry and heard water. thought water from shower due to daughter was taking shower then realized carpet in hallway soak a nd wet water just running over. had to stop and turn control to spin to release water to drain and get steam cleaner out to soak up water. i was told it's a switch is this true or what do you recommend.
thanks
cbryan
  • 686 Answers
Yes it's your pressure switch. It is either bad or you have a clog in the line from the tub to the switch. Open up your control panel and find the clear hose that attaches to the switch. Disconnect it and blow through it. You should be able to blow through this hose with no resistance. Re-connect and try a new load. If problem persists change the pressure switch.
Posted on Jun 01, 2009
Nujky77575y5
Posted on Feb 09, 2011
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
Washer will not stop filling up with water and won't agitate
Is the standpipe for the drainhose at least the height of the basket or control panel?
May 26, 2012 | GE Washing Machines
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Ice maker not making ice.
TRY DISCONNECTING THE ICE MAKER FROM INSIDE AND RUN HOT WATER OVER IT UN TIL IT IS COMPLETELY THAWED, THEN RECONNECT IT AND SEE IF IT WILL MAKE ICE NOW. SOMETIMES ICE MAKERS CAN BECOMED BLOCKED BY ICE.
Apr 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Peugeot 306 won`t start off ignition
check your glow plugs they may be damaged or dirty
May 25, 2009 | 1991 Peugeot 405
At shower time in the morning the hot water varies from cold on one day medium on another and hot on any given day. What's wrong?
Do you share your hot water with anyone? Is anyone washing dishes, laundry, etc before you shower? How old is your hot water heater? If it has filled with sediment, your hot water is limited. Try turning up the heat control valve on the hot water heater, only go up one notch today, then if not enough another the next day. Be cautious of scaulding hot water after turning it up.
Apr 10, 2009 | Water Heaters
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Crosley CAWC529JQ Top Load Washer Logo
283 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
