Question about Dell Inspiron 6400 Notebook
Wont connect to belkin 54g with wpa security applied
Can connect to belkin 54g wireless router via other laptop when using wpa security but his laptop Dell inspiron 6400 with Intel(R) PRO/Wireless 3945ABG with updated driver will not aquire network address when used with wpa security. If used without wpa security works fine. Please can you help !
  • Chris Hingee
    Chris Hingee May 11, 2010
    Did you configure the wireless card with the same WAP encryption that you set on the Belkin wireless router?
    Problem Solver:
  • 10 Answers
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Posted on Jun 20, 2009
  • Smartkid2009 Jun 20, 2009
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
I want to secure my belkin 54 router, its not secure now
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is 192.168.2.254
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
May 03, 2011 | Belkin (54G F5D7230UK4) Wireless Router
I need to secure my belkin 54g so other people cannot use it, how do i get to the setup page first?
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 15, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I have 2 computers - a desktop without wireless and a new laptop with wireless. I want to connect the Belkin N150 basic wireless router to both these computers. I have introduced a "wired"...
UNINSTALL THE BELKIN ROUTER MANAGER FROM THE LAPTOP
Step 7 : Enable 64 Bit WEP ( WPA WILL NOT WORK )
Dec 21, 2010 | Belkin Basic Wireless Router
Change my settings from wep to wpa I have a belkin 54g
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
Jan 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How to secure belkin 54 wireless router
Easiest wsay is to connect via cable and go into the configuration pages and set the security from the menu. Discoonect and then go into the wireless network settings on the laptop
Dec 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Dell Inspiron 6400 Notebook Logo
598 people viewed this question
Alun Cox
