Blowing Fuses.... is this fixable?
Hi i have a Rca Truflat 32 inch t.v. and its dead has no power or anything when i plug it in so i opened it up only to notice that the fuse was blown so i had replaced it and pluged it in then as soon as i did i saw the fuse blow again is this fixable?
SOURCE: Blows fuses
I found a post where someone replaced several capacitors with ones he described as titanium and a higher voltage like 100 v rating rather than 50 as oem. He states no more problems. I found this site while searching again. I also found a free download pdf repair manual from JBL - site defined as Harmon, and they show revised parts replacements for these caps - 100 volt. I just bought a used one and not hooked up as yet, but I plan to use slow blow fuses and possibly a little higher rating - not much though, and I believe there is a ceramic type - color solid white - that may withstand the apparant surge. Theres also a recent post somewhere for sale of the amplifer board... 64smi or something like that. Hope this helps. Ken
Posted on Mar 24, 2007
ctf1800
  • 4402 Answers
SOURCE: RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Posted on Dec 05, 2007
  • 1153 Answers
SOURCE: RCA PROJECTION TV MODEL # P46731AT
A short in the PS. Does it blows as soon as you plug in or when you hit power? It makes a different. For more info ctechnicians.com
Posted on Jan 07, 2008
djdizzys
  • 22 Answers
SOURCE: M-Audio DX-4 speakers blowing fuses
could be a problem with the wires? good luck
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Posted on Mar 10, 2008
32 inch rca getting power, but wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_29_2012_3_02_02_pm.jpg
left one is good and right one is bad.
Arrows point to bad ones
May 28, 2012 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
My tv doesn't come on but it acts like it want's to
It ur high voltage is dead.The FBT,the flyback transformer it dead.The big block of plastic with a red wire with a cap hook to ur CRT(tv tube).That thing it dead.
Sep 26, 2009 | RCA TruFlat 27F520T 27" TV
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
RCA 32'' TV making a humming noise
sounds like a shorted horizontal output transistor probably caused by the high voltage transformer or hot. it is most likely fixable but it will be costly.
Aug 19, 2009 | Televison & Video
My RCA 32 ' SDTV TrueFlat doesn't come on
sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
My rca d52w14 52 inch will not come on
if you have a multitester handy, measure the resistance across your tv plug as you press the main switch, if you get infinite resistance, check for fuses. you have to open it up, if you are nor sure you can do it, visit your local service center
Jul 08, 2009 | Televison & Video
Fpa lock on my rca tru flat tv
here is my solution. somebody either needs to give me a solution without a remote or fuckin mail me a remote. and if i ever run into these RCA dipshits, ima beat some ***** *** for puttin the damn lock on there in the first place.
signed,
Jay and Silent Bob
Dec 26, 2008 | RCA TruFlat 27F520T 27" TV
Feb 10, 2008 | M-Audio Studiophile DX4 Computer Speakers
RCA TruFlat just up and died...
I had a problem similar. I found the menu tac switch leaky
Dec 04, 2007 | RCA TruFlat 27F520T 27" TV
Won't work
It sounds like something in the high voltage (flyback) circuit failed. If any little thing shorts in these RCA's they will not start up. Stargazer
Apr 15, 2007 | RCA 32F530T 32" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
