Question about Kenmore 22422 Top Load Washer
Kenmore washer will not spin in rinse cycle
Kenmore model 23832100 washer makes noise (grinding), will agitate (weakly) and drain but will not spin in rinse cycle. checked coupling and found no damage or wear. checked agitator clutch and it looks and functions ok (maybe some wear). i have heard that transmission malfunction is unlikely, but this seems to be a major problem. please help with any suggestion, i'll try anything...
  • 686 Answers
I thought I had posted you a solution but not sure if you have gotten it. Anyway here I go again. To inspect your coupling you need to drop the pump and the motor so that you can get a good look at the coupling it consists of 3 pieces. Go to www.repairclinic.com enter model number and click on the first part you see to get additional images. If any of the prongs are broken replace the entire unit. You can call me at 417-926-0106 if you'd like.
Posted on Jun 01, 2009
2 Suggested Answers
lester482529
  • 226 Answers
SOURCE: kenmore model 23832100 washer will not spin in rinse cycle
the motor it's self may be getting weak this happened to me.try running it through a small cycle with no cloths in it .holding the buton down under the with a small object so you can have the lid open to see exactly what's going on.if it seems too work like that.your probably talking new motor.
Posted on Jun 02, 2009
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Not draining..agitator making a grinding type of
The bad news is with the combination of not draining and the grinding it is undoubtedly the drain pump. The good news is they are not difficult to replace. Let me know if you need any info on replacing it yourself and I'll try to give you the steps needed.
Hope this helped.
Sep 14, 2009 | Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore washer model #23832100. It will
Yes....the lid switch is broken...will need to be replaced.
Jun 10, 2009 | Kenmore 22422 Top Load Washer
Jun 02, 2009 | Kenmore 22422 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
547 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
