Question about Weather King 10AJA2501AH Air Conditioner
Weather King blows fuse in Criterion II furnace
My exterior one year old Weather King fan keeps blowing one of the fuses. Please help. When the air conditioner kicks on it blows a fuse in the furnace near the blower (looks like a 10amp car fuse connected to 2 wires). I replaced the fuse, turned the power back on, and it immediately blew the fuse but didn't kick on. The fan, heat, or cool will not work. What could be causing that little fuse to blow over and over again? It was working fine 2 days ago!
  • 14 Answers
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Posted on Jun 03, 2009
We have a King Pellet Stove 1 year old. Fuses keep blowing. Have replaced ignitor and fuses several time. Is a surge protector the answer or is it the circuit board? Thanks!
Please understand the reason for fuses blown:
1. High amphs of the main part in the unit. 2. Short circuit 3. Loose wiring. 3. Wire contacts corroded due to rusted or dusty.
Dec 12, 2010 | Heating & Cooling
When i turn the a/c on the inside furnace motor runs but the outside compressor units does not. the compressor is a janitrol, about 20 years old
Does the outdoor fan run? If not then start by checking for tripped circuit breakers or blown fuses. If you have power then check the capacitor. If that is good then check your contactor for the fan and compressor. If that is good then check the compressor motor windings. Let me know if you have any questions.
Jun 14, 2010 | Weather King 10AJA3001AH Air Conditioner
Transformer
what you need to do is isolate the loads that are on the transformer and put a amp meter on the transformer and read the amps while you put the loads on one at a time. the one that spikes is the one thats bad. You can put a inline fuse in to protect the transformer. A 3 AMP fusw qould be good for a 75 va transformer if its a 50 va you would need a 2 ampo fuse.
Jan 13, 2009 | Weather King 12AJA4801AH Air Conditioner
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Weather King: model # 13AJA60A01
HEY< the compressorstart-up amps is 2-3 times the run amps. Once it gets up to speed, then the small run amps is all thats needed to keep it there! The one time fuses--assoon as it hits the rated amps it blows to protect the system, the slow-blow fuses has a few seconds to heat and blow if the amps stay to high and don't go back down below the rated amps! Thank-you-very-much
Aug 30, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King split AC system.
Turn the power off ,and check all the electrical connections for loose connection or wires. also make sure these are slow blown timmed delayed and not one-time fuses. Thank-you verymuch!
Furnace not blowing hot air
Check your flu pipe and make sure there is no obstruction in the entire pipe. Sometimes the exhaust fan for the flu will not come on because the safety will not allow it to and it will also cause the fan to run, but not the burners to engage ignition.
Hope that helps.
God Bless.
Erik
Aug 08, 2008 | Weather King 12AJA6001AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
279 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
