Question about Kenmore 63942 Dryer
Kenmore 70 series model 110-66752500
The dryer comes on but no heat-i took off the back panel and look at all the connections and they seemed good-i cleaned out all the lint that i could get too-it just does not have any heat
  • 5,911 Answers
The following link explains how to troubleshoot a dryer not heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Begin by verifying the wall receptacle for the proper voltage. If the voltage is not reading between 220-240VAC, this will also give you the same symptoms.
Cleaning out the lint is a good start, but if the lint has accumulated over a period of time, the dryer may have overheated. This usually results in the thermal cut-out (TCO) blowing. The TCO acts as a fuse and once it blows, it must be replaced. Your heating element will be located in the heater box on the right hand side of the dryer with the back panel removed. The TCO will be located at the top end of the heater box, while the hi-limit thermostat will be located adjacent to the ceramic heating element terminals. If the TCO proves to be faulty, replace the TCO and Hi-Limit Thermostat at the same time. The two components are usually sold as a set as part number 279816. You can find these parts at searspartdirect.com or appliancepartspros.com under the "Bulkhead Parts" section as item number 1. Just use you model number for your search criteria. Failure to replace both parts may result in premature failure of any replaced components.
Read through the link provided and let me know if you have any questions. Pay particular attention to the section that discusses proper dryer ventilation. If kept in a clogged condition, the dryer will continue to overheat to the point of failure. Not to mention, this is a fire hazard. I hope this helps you.
Posted on Jun 01, 2009
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore gas 70 series dryer not heating up..
you'll need a meter,check the ignitor, and the sensor,if these are good you have bad gas coils or gas valve,come back with full model number and check to see if ignitor is glowing
Nov 07, 2009 | Kenmore Dryers
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 63942 Dryer Logo
442 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
