Question about Vertex FNB-27, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 600mAh NiCd 2-Way Radio
Ft530 heating up on rx
My ft530 gets hot enuff to burn my hand, even tho it is on rx it discharges the fnb25,i have 2of them and 2 chargers still the radio heats up i
Kenwood 44s 28mhz to 24 mhz omes on and gos away
Posted on Jun 03, 2009
How do u know when a circuit board gets hot
Usually, it's one or two components that get hot - not the entire board. You should never touch a circuit board while powered to "feel for heat". Disconnect from power (unplug, shut off circuit, etc.) and wait a moment for capacitors to safely discharge. Check all components with a volt meter BEFORE touching them with your hands. You may also look for discoloration on the board near a component. If the component is raised off the board - it may not cause the board to discolor - as the further away from the board it is the less likely it will be to cause discoloration. High heat components have "heat sinks" that are larger pieces of heat conducting materials that are in physical contact with this components designed to wick heat and transfer it to the chassis, frame or air. These components will be warm or even hot to the touch - but it will be difficult to know if "too" hot as a result.
Oct 27, 2015 | Pool & Spa
I have broken sunon maglev ventilator in acer aspire
Replace the inner part of the fan - some unit just slip right out.
check on kijiji and find a local computer repair guy that will sell you one for 5 or 10 bucks, or get a broken laptop for 50 to 100 and lots of parts. I had one broken wing and broke on off the other side to even it out... even though one side had 1 extra wing it wasn't that far off balance so vibration should be minimal.
if you keep your laptop clean inside around the heat-sink and fan area and put silver heatsink on the gpu and cpu as well as install the manufacturer drivers and update them to cool things down and speed things up and keep things from heating up.
One more issue is the charging port and charger end get frayed and or loose and will cause heating issues and have caused fires.
Replace batteries that are weak as they are continually charging too much.... Store batteries and at 70% and don't pull them out of the laptop while it's plugged in.
Fully charge batteries and fully discharge them between charges.
Good to have 2 batteries.
Don't use hot batteries especially after charging and don't charge a hot battery.
aka Mr.Fix-it!
East Coast Canada
Apr 05, 2013 | Acer Aspire 5734z-4725 Fan Sunon Maglev...
Smelly black discharge from hot water every so often seems like a chemical reaction with well water and what heats the water in the tank. When turn off power and let the hot water sit for awhile there is...
Turn off water heater and flush it out. Hook hose up to hose bib on water heater.Close valve on hot water side.Run hose outside or into a drain.Open valve where you hooked up hose and let run 20 to 30 minutes to clear out tank.I would recommend putting a filtering system on the line going into the tank.This should clear up the problem.If not you have to have the anode rod replaced,depending on the age of the water heater.If you want to learn more about the anode rod,google anode rod ,it will bring you up to a site that will explain to you what it is. You will have to go to a plumbing supply store to find one.
May 31, 2011 | Little Giant Water Heaters
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot...
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
My uniden cordless phone is not recharging, even tho i bought today a new battery at 17 dollars a pop at radio shack. the regular part of the phone unit with the answering machine on it works fine, help???
Your phone charger is shot. New batteries will not help if your battery heats up during charge or stays hot when left on charge. If the battery never gets warm and your charge light doesn't come on then it is a different problem. The phone manufacturer suggests you buy a new phone.
Sep 08, 2010 | Uniden Cordless Phone
Missing band selector.
more than likely you cannot i would suggest to get a new boombox.
Jun 10, 2007 | Panasonic RX-FT530 Radio/Cassette Boombox
Radio Communications Logo
116 people viewed this question
Top Vertex Radio Communications Experts
eradiostore
eradiostore
k24674
scott265
Level 1 Expert
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
