Question about Jenn-Air JXT8030ADS Kitchen Hood
Jenn-Air JXT8030ADS kitchen hood has stopped working
No response out of the control panel on the hood. Lights or fan not working. Is there a fuse in the hood that may have blown?
Although there was still power going to the hood, my husband decided to try flipping the breaker. This must have reset something in the fan as it is now working.
Posted on Jun 02, 2009
  • Perry Makinen Sep 15, 2013
    I just had the same problem where power was showing but nothing worked. I reset the breaker in the panel and it started working. Thanks for the first tip!
Unit has no power. Circuit breaker OK. Is there a fuse somewhere in the hood?
Very likely the power supply unit is faulty or the controller itself. The parts list shows no fuse internally. The power is directly going to the control board (item 3). Make sure you turn power to the rangehood off at circuit breaker before working on it.
JENN AIR Vent Hood Hood components complete Parts Model JXT5830ADS
Sep 06, 2014 | Jenn-Air JXT5830AD Kitchen Hood
MY jenn-air hood vent JXT8036ADS LIGHTS STAY ON EVERTHING ELSE WORKS
I fixed a JXT 8030 ADS that had the same problem. The lights are driven by a Triac located on a circuit board (SV158D) placed inside a plastic box (ref: AP4052900). This is not the '''control board'' with the switches. In my case the Triac was bad. To fix this you need minimum skills in domestic electricity and electronics mostly for desoldering, testing the triac and resoldering the original or soldering a new identical Triac in place. Also, you will have to secure the heat sink to the new triac and don't forget the thermal paste. The Triac will cost you about 2$. Enclosed is a few pictures, the triac is right beside the wiring that runs to the lights. Good Luck and be safety wise if you attempt this fix. Michel.
p1010932-xzvfllqdgu0z021h5pfuakwa-2-5.jpg p1010933-xzvfllqdgu0z021h5pfuakwa-2-3.jpg
Feb 15, 2012 | Jenn-Air JXT8030ADS Kitchen Hood
Changed a buld in hood and it touched casing as I was inserting. Tripped the breaker. This is reset but now have no power to bulbs or fan. Is there a trip in the hood?I dont have the model number, it is a...
check to make sure you have power back to the junction on the hood,sometimes just resetting the breaker wont do the trick,it may be a wire at the hook-up open now,there may be a fuse protecting the unit itself for the fan control,but the lights are usually wired direct so re-check the incoming power first
May 02, 2010 | Jenn-Air JXT8136ADS Kitchen Hood
JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Jul 04, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
Jenn Air stove wired backwards
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
May 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Lights won't go off
We will have to contact a technician.
Jan 03, 2009 | Jenn-Air JXT8030ADS Kitchen Hood
COOKER HOOD STOPPED WORKING. FAN AND LIGHTS
Power problem....controls ...on going replace
Apr 11, 2008 | Jenn-Air JXT8136ADS Kitchen Hood
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Lights stopped working
Have you opened the hood at all? Service instructions should be on the cover of the controller box. FYI the fuse is on the 12V side of the transformer so it which feeds triac controlling lights and controller board so nothing works when it blows.
Sep 23, 2007 | GE ZV850SBSS Kitchen Hood
Jenn-Air JXT8030ADS Kitchen Hood Logo
466 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
