Question about Fahrenheat FFH1615 Heater
Low air flow
Ever since new, the fan doesn't move much air, the heat doesn't blow out quickly, the bathroom takes a long time to warm.  Is this common with this heater or did I just get a dud, would a different brand move more air?
  • 625 Answers
Most fan forced wall heaters do not move a lot of air. check the cfm rating on the heater. the fan sucks in air from the bottom and forces it up to the top where the element is. broan and nutone have good air flow.
Posted on Nov 04, 2007
Why my heater flames will not contenue working its stays a few second then gone.
Posted on Dec 07, 2008
A/C Blows warm when idle
I can't say much without having the actual code.
When the ac stops blowing cold at idle, the most common reason is not enough air flowing thru the radiator, or the radiator fan is not running and the only air flow is when the vehicle is moving.
May 09, 2013 | 2005 Chevrolet Colorado
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
Is there a fuse or relay for the heater in my 2002 ford expedition
No hot air is due to low coolant, or even poor coolant flow. The engine heats up the coolant, and it passed through your heater core, and the heater blower motor pushes air through the heater core to warm up the air. If your "fan"is working, but the air is cold, make sure your coolant level is good.
Dec 08, 2011 | 2002 Ford Expedition
Heater not blowing warm air
the windstar has a problem with heater control doors
Nov 30, 2011 | 2000 Ford Windstar
Air from the heater is not really warm.
Have you changed your air filter lately?
Dec 03, 2009 | Heating & Cooling
Why does the heating element in my gas furnace keep shutting off before it reaches the desired temp? The fan keeps blowing but the air is cold. I have to turn the thermostat to off, wait a few minutes and...
The furnace has many safety controls monitoring many parameters. The most like cause of your complaint may be low air flow. The most simple reason would be dirty or too restrictive of an air filter. If the filter is clean that is about as far as you can go without a general knowledge of how that whole system works together.
Nov 01, 2009 | Ruud UBHC Air Conditioner
HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
May 26, 2009 | Heating & Cooling
CHEVI LUMINA 2001 HEATER failing...might have slow dex-cool leak
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow.
If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm.
If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air.
If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted.
One or a combination of these factors is likely the culprit in your case.
Flush the heater core 2-3 times, and if the obstruction does not clear, a new heater core is required.
However in your case, a cracked head is suspected - this will give out a plume of white smoke on startup - There is no smell, carpet dampness, or abundant moisture in the cabin? (this warns of a leaking heater core)
The coolant is leaking through a gasket or crack, and entering the combustion chamber. You dont see a leak on the ground because it is being burned up with the fuel.
Good Luck, and thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | 2001 Chevrolet Lumina
Heat
If this car is remote start GM has a service bulletin out to do a computer flash to correct this problem, it will probably blow hot air in the summer if it remote started if you don't have the computer flash done. Hope this helps
Dec 05, 2008 | 2007 Chevrolet Impala LS Sedan New Cars
Fahrenheat FFH1615 Heater Logo
184 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
