Question about Acer Aspire One PC Notebook
Acer Aspire one will not turn on.
I had my laptop plugged in overnight. I turned it on and checked my email and looked at some news then turned it off. We went out for a few hours and later that day I opened the lid and hit the power button and nothing. It will not turn on, plugged in or just with the battery. I see the green light on my power supply so I "assume" it was working. My laptop is one month old. I was browsing the web yesterday evening and my computer seemed to be woring fine and then firefox froze. I selected restart from the power menu and the computer seemed like it was restarting, however it never came back on. If I press the power button the machine sounds like the fan is working but none of the lights (apart from the power on button) 'light up' and nothing happens. Please help. Thanks
    Guru:
  • 597 Answers
If this laptop is one month old why even mess with it. Take it back to the manufacturer or store where you got it and get it fixed on warranty. Never fix something you're not sure about when you can get a professional to fix it for free.
Posted on Jun 01, 2009
  • 2,229 Answers
Try this first: Unplug your computer. Now remove the battery. Wait maybe 10 minutes and replace the battery. Now turn the computer back on. If it is what I think it is, Vista has a problem waking up from hibernation. This is the only way to wake it up.
I know that Microsoft has a fix, but I can't remember what it is (as I don't use Vista).
If your computer is new, it's still under warranty,so call the manufacturer if this doesn't work. Heck, you paid for warranty service,so you best use it.
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
What to do when Acer desktop aspire 1461 turns on but screen is blank
Plug in an external monitor to the VGA port to the laptop. If that works - that's great news! The LCD screen is bad. Simply replace the LCD of the laptop's display.
If it doesn't work; you need to replace the VGA chip or the entire motherboard if it is embedded.
Jul 02, 2014 | Acer Aspire One D270 Netbook PC AOD270...
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://doube.org/aspireoptical
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5602wlmi sound problem with Windows 8
You should look in the Default Devices section of the settings. But it could just be bad contacts in the jack plugs of the sound card.
May 02, 2013 | Acer Aspire 5602WLMI Notebook
Acer aspire 5736z-4460 won't turn on
tried to remove the battery and then re attached, turn on the pc laptop check if it works.
Aug 03, 2012 | Acer Aspire 5736z 4460 Laptop
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
Acer Aspire 6930 will not turn on.
there is small problem wtih Aspire One. need to bios update. take the service they will do it free.
May 31, 2009 | Acer Aspire One PC Notebook
Will not turn on
maybe the fan have stopped
May 16, 2009 | Acer Aspire 3680 Laptop
Acer Aspire One  PC Notebook Logo
734 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
