What windows OS are you running? XP, Vista, 7?
Typically you can add speakers with little to no effort. You will need to check the plugs on the speakers. Is it USB? or are they small 3.5mm jacks?
Usually speakers use 3.5mm jack and depending on the type of speakers they will have either 1 connector or 6 (for 5.1 surround sound)
Once you determine what connectors your speakers have, make sure you have the matching connectors on the back of the PC. These are usually colour coded Green (for a single 2.1 connection) or multiple colours for 5.1. USB is the small rectangular connector that is short and wide.
If you have the 3.5mm connectors, just plug them in to the back of your computer and plug the speakers in to a power source and they should begin working without drivers.
If you have the USB connection you will need to determine the model of the speakers and find the driver online:
http://www8.hp.com/ca/en/support-drivers.html
Install the driver and then plug in the USB connection and windows should automatically install.
You could also try to let Windows update find drivers online for you.
Hope this helps.
