Question about Ruud UAKA060 Air Conditioner
It's not maintaining inside temp with thermostat setting
I have a ten year of RUUD Model #uaka-060JAZ that is on its last few days and I would like to know what a fair replacement price should be and where can I find that info on the internet.
  • joshuaramsey
    joshuaramsey May 11, 2010
    Can you tell me the tonnage of your unit? I could give you a good budget replacement price based on that. Also, would this be just a replacement of the outdoor condensing unit and indoor unit? Thanks.
  • 24 Answers
Replacement cost vary a lot depending on what type of equipment you are going to upgrade to. the new 13 seer mandate has driven up cost quite a lot in the past few years. the older units only had to be ten seer and most manufactures go all the way up to 18 seer but regardless you will have to go with 13 as that is the law now. the best advice i can give you is to call around to local contractors and 99 percent of them will give you free estimates on replacement of your equipment even proper bids that normally are good for 30 to 60 days. get as many bids from as many different companies as possible and let them know you are shopping prices but remember have them all bidding on similiar equipment so they are'nt bidding apples to oranges. also there are some tax credits available for some systems with higher efficiency ratings. also be aware that many manufacturers offer 10 year warranties on equipment and some have lifetime compressor warranties. Reasearch online for some of these suggestions. you can look up goodman-amana, york, bryant, rheem-ruud and see what offers they may have going. the contractors will guide you through most of this and offer many suggestions videos and brochures.right now times are slow for alot of a/c companies so now is a perfect time to start shopping.
Posted on Jun 02, 2009
What ton is a ruud uaka-060jaz
This is a 5 ton unit. There is 12,000 btu's per ton, so you would multiply 12,000 x 5 = 60,000 btu's.
May 10, 2014 | Ruud UAKA060 Air Conditioner
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Have a 11yr old RUUD Uaka 060jaz with the A coil frozen, solid, no air getting through. Service tech came out and charged system with minimum 3lbs of r22 but suction pressure wouldn't go above 6
Hello, typiccally with noncondensables in the system your head pressure would be alot higher. 175 is pretty low high side pressure. Usually coils will freeze due to either low airflow or low refrigersmt charge not becuase of non condensables. I would get a second opinion from a differant company.
Jun 28, 2012 | Heating & Cooling
What is the ton of my Ruud model # uaka-048jaz Serial # 543w m0603 11165 ?
The "048" in the model number means that it is a 4 ton unit...12,000 btu /ton... it is a 48,000 btu unit, so it is a 4 ton unit...
heatman101
May 02, 2011 | Ruud UAKA048 Air Conditioner
If the ambient temperature is the same or less than the temperature in the fresh food cabinet of a refrigerator with the freezer on top, will the stat ever call for cool? sub question---where is the...
Yes, and if you turn the thermostat colder and the thermostat is in good condition it will. You model was made with a mechanical thermostat with Freon filled probe. You may need to close the cold air flow to bottom during extreme cold days and redirect the thermostat probe closer to the freezer opening but it should work. My refrigerator worked fine in ten inches of snow last year and temps in the teens. Thanks, Sea Breeze.
Jan 17, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Ruud UBHC-21J18SFA blowing only "luke warm" air at best
That's crazy, we're having the same problem.  Turns out there was a wattage restrictor in the furnace that was switching off 3 of the 5 heating elements in an attempt to save energy.  Basically, the restrictor was sensing that the incoming air was warm, so only 2 of the 5 coils should be needed to heat the air.  Well that wasn't enough and we just sat with the furnace running all day long struggling to reach the 70 degree setpoint.
This is something a technician can diagnose in a few minutes, but not the sort of thing a DIY'er should really handle.
Dec 22, 2008 | Ruud UBHC Air Conditioner
Ruud UAKA060 Air Conditioner Logo
276 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
