Question about ASUS M2N-MX Motherboard
No bios computer will not boot
Have downloaded several bios versions, computer will not read them. just get message floppy not found reads cd but wont install new bios
    Guru:
  • 597 Answers
You have to have a bootable floppy disc
Posted on Jun 01, 2009
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
Lost restore disk,want to install oem windows xp. computer doesnt read disk
I assume you're saying that the pc is not booting from the DVD/CD? If that's the case, you
need to go to the BIOS setup, where you need to change the device boot order. It's now
probably set to start running from the hard drive, reason why your DVD/CD is not booting.
To go to the BIOS setup, press the F2 or delete, or whatever key the first POST messages
instruct you to use to go into SETUP mode. Different BIOS manufacturers use different
keys, so you have to be quick and interrupt the boot process using the correct key. If you
fail to determine what key it is, reboot once again, until you see/read what key does the
job.
Next, once you're into the setup screens, look for one set of options called Boot Options
or Boot Order. Read the instructions to learn what keys to use to change the values.
Ensure that the first device accessed is the CD/DVD drive, then whatever else next, etc.
Once that's done, save your settings following the prompts, load your DVD/CD and reboot
again.
That should read the disc and start the installation.
Aug 21, 2009 | Dell OptiPlex 170L PC Desktop
''Platform signature not found in the interface'' BIOS HELP!
I remember a time when floppy disks were actually stable.
More than likely one or more things could be the cause of your headaches..
1) the floppy disk is flawed, or not properly formatted.
You can go to www.bootdisk.com and download a utility that will write a windows98 boot disk to your floppy.. this method writes per cycles, and checks that the write has been successful, once written, and booted into, you should be able to swap the floppy disk out for one with your flash utility, and bios file on it.
2) the floppy drive could be faulty. I have seen several drives claim to have formatted a disk, but infact had not because the read / write head in the drive had gone bad over the years.
3) There may be a memory problem on your system, faulty, yet funtional memory modules are all too common. When you boot from a floppy, most times they store the " dos " operating system in memory to save time from reading the floppy disk again and again.
May 31, 2009 | Gigabyte Computers & Internet
No procecer bios update found
that message means the system isn't reading the cpu or processor. If you have done an update it could have caused it or it could be a bad motherboard component/processor. I'd first update the bios. Press F2 to enter bios.
http://support.dell.com/support/downloads/download.aspx?c=us&cs=555&l=en&s=biz&releaseid=R86320&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&deviceid=162&devlib=0&typecnt=1&vercnt=3&formatcnt=1&fileid=113058
You'll have to do this on a floppy or cd and change the boot to your drive usually B for floppy and D or E for CD
Or you can boot to DOS and use the following:
put in drive letter using D as an example Replace the D if floppy with A or B or E etc... D:GX270A06.EXE Change boot order back to hard drive. Try to boot again.
Mar 28, 2009 | Dell OptiPlex GX270 PC Desktop
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
ASUS M2N-MX Motherboard Logo
133 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
