Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Converting from natural gas to propane
I have the kit. How do I get the front lower panel off my Whirlpool Sport Duet to gain access to the ignitor? Don't want to bugger anything up on this new dryer.
Thanks,
Gary
  • 121 Answers
You need to change your orfice or you will have a big problem with flame
Posted on Jun 02, 2009
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I just converted my DUET "sport" dryer from propane to natural gas,orfice and regulator cap, and now the burner does not come on.
Hi, I'm going to start with asking the most obvious thing, no offense. Is the gas turned "on"? Does the hot surface ignitor "glow" ? The valve should be open at the burner supply tube as well as the dryer supply line. I've seen it happen often where the burner valve was shut "off" and forgotten when the repairs/conversions are complete. You could loosen the fitting at the burner to insure you're getting gas flow to that point. That way you know for sure it's likely a bad ignitor or coil etc. The ignitors are quite sensitive, and if disturbed or knocked around can crack, then it's toast. Hope that helps, good luck
Oct 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Convert from natural gas to propane
it is very simple
pull of the botom toe kick
3 t-20 screws
once the toe kick is off
you will see the gas valve
disconnect the ignitor
remove one 5/16 screw
the whole assembly will slide out
if you look at the top of the tube
you will see the brass orifice
this needs to be replaced
Oct 05, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have a whirlpool duet gas dryer. how do I open
1. Unplug the unit while servicing inside.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Convert Whirlpool dryer from propane to gas
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Access to burner on Frigidaire Affinity AGQ6000 series dryer
you do have to pull out the unit and use the rear access to unscrew those screws accessable from the inside.
Feb 18, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
150 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
