Mitsu WD-52525 DLP, small 1/8'' diagonal lines across screen
I know this TV has all sorts of issues, it started 1 month ago with 3 greyish circles on the screen in various. Bought the 4yr BestBuy warrenty with the TV, service shop did not even come out, they said they had a similar issus and it was the light engine. They a engine picked up the TV tried to install the engine and said it was defective, they ordered another one, installed it and let the TV run over the weekend, all seemed fine. TV service brought my TV back was watching later that night and noticed these thin lines about 1/8'' maybe running diagonially from right to left, if you look close, they look to be faint green and violet lines. Talked to TV service today 6/1 they are working on TV again, tech said he saw the lines when the TV was at my house but the lines do not appear at the shop, tech says it could be a faulty ground in my homes electrical system and they are bringing the TV back. The thing is I did not have the lines running through the TV until they serviced it the first time and replaced the light engine. Any ideas, bestbuy warrenty has expired and getting help from them is like pulling teeth.
  • 10,594 Answers
Symptom shows problem with DM module (digital module) and its costly part approx $535
Since TV is out of warranty so its better to ignore these thin lines and save money, and if still want to replace DM Module then its available in Part Store.
Thanks.
Posted on Jun 01, 2009
My 65" DLP T.V. has started having small white
Optical-Eng PN# 938PO75020 Encompass Parts Distribution has 5 left in Stock
Price $1,415.51- core fee $300.00 Final Price $1,115.51 1-800-638-3328
PTS rebulit Optical Eng. 1-800-844-7871 Call and ask what they charge.
Nov 02, 2010 | Mitsubishi WD-65733 65" HDTV
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with green horizontal lines
You need to replace the capacitors on the FMT PWB this is a common problem with the V26 chassis which is what your model number is. They have some bad capacitors that need to be Changed. There is a repair Kit available for the FMT repair.Let me know if you would like the link for the repair Kit. Please respond to this same post if you do want the repair kit which does involve soldering.
Jul 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 DLP HDTV screen went bad
i have the same tv i got it for free from my work it was a return there's no picture or sound but the green light blinks on the timer light i took it to a tv repair place ive researched the problem alot most forums said it would be the dm module or the capacitors on it but this guy is sayn its not that and its not the lamp but it could be the color wheel or some balance thing he was bein an a hole about it i paid for a diagnostic and he said hes not gonna look at anymore cuz i dont sound interested in payn what he says MIGHT be the problem and i dont want to get screwed for a bunch of money any tips??? thank you
Aug 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
