Question about Intel DG33BU G33 Express Socket 775 mATX Motherboard w/Video & Sound
My pc can not find boot device
Whenever I turn on my pc, I receive the following error.
Controller Bus#00, Device#1F, Function#02: 06 Ports, 01 Devices Port-00:
and then a message ''no boot device found'' and after restarting the computer, everything works fine.
Please help to solve this problem.
  • 107 Answers
I think its a motherboard battery issue! When you first turn your PC it finds and reconfigures its devices. Then you do restart and it boots because everything configured. Battery keeps your hardware configuration when you turn your PC Off. Try to replace a battery! Good luck!
Posted on Jun 01, 2009
    Scholar:
  • 75 Answers
There's a system rechargeable battery inside the PC casing which helps retain system settings. it may have given up the ghost. you could try replacing the battery...
    Problem Solver:
  • 10 Answers
Locate the cmos jumper and move it over for roughly 30 seconds then pull and put the battery back in the computer
this clears all issues that halt cmos then your computer should fire fine
Posted on Jun 02, 2009
4 Suggested Answers
  • 165 Answers
SOURCE: problem with usb ports
A usb device may have blown out some of the ports, If you have at least one working usb, get a powered usb hub to get more ports.
Posted on Jun 10, 2008
mrsno
  • 166 Answers
SOURCE: Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Posted on Jun 18, 2008
hari007_in
  • 138 Answers
SOURCE: a question mark in S M Bus controller and video controller
i feel you are not having the right drivers,, for the video card,, you try go from device manager,, and from there click on properties,, and then. update driver.. then give path to the relevant drivers... let me know the video card name and details
Posted on Sep 27, 2009
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Whenever I turn on my laptop I get the Error: Resource Conflict-PCI Network Controller on Motherboard Bus:08, Device:00, Function:00 Bus:08, Device:01, Function:00
You have a device that is attempting to use the same IRQ as another device that has loaded before it. Go into the device manager and look for a device that has a yellow triangle with an exclamation mark inside. You may find a couple.... Open the device properties and see if you get some indication of which other device it is having conflicts with. Then it is a matter of uninstalling one of the devices and rebooting, letting Windows re-detect the device and install it again...hopefully with the correct IRQ assignment this time.
Feb 17, 2010 | HP OmniBook XE3 Notebook
This means that at times your hard drive can't be found due to either the hard drive not working or that laptop not being able to find the hard drive due to either a motherboard problem or the ribbons that connect the motherboard to the hard drive. This problem will probably continue to escalate until the hard drive, laptop or the ribbon fails. You could try replacing the ribbon first as it's probably the cheapest to replace if you can find one then change the hard drive and if that doesn't fix it wait for the lap top to fail.
Jun 01, 2009 | Acer Aspire 5100 Notebook
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Intel DG33BU G33 Express Socket 775 mATX Motherboard w/Video & Sound Logo
301 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
