Microsoft Office Word 2007 Full Version Corporate License for PC (059-05468) Logo
Posted on Jun 01, 2009
Word 2007 form fields
In word 2007 how do I populate a text field farther in the document from a drop down field.
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Aug 16, 2009
Anonymous
Contributor
Level 1:
Answers
49
Questions
Helped
7538
Points
91
You have need for assistance at your home only!!
How can I add a "hot key" to my iPad. I want to be able to fill in values such as my email address in one keystroke. Is this possible?
If you use Google Chrome and login with a google account, you can save responses to fields when you fill in forms and it will auto populate those fields on other forms. Typical fields are first/last name, email, address, phone number(s)
3answers
I have word 2007 and windows 7. The speller ignores many very obvious spelling mistakes in my document. I think that I've embedded text with paragraphs that are somehow marked as "not for spelling"....
Open word 2007
Go to tools->Optios->Spellin and Grammer.
Then enable all checkboxes then apply and ok.
If still face same issue then you need to repair your word 2007.
Let me know if you need further assistance.
Thanks for using FixYa.
1helpful
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
No available fields in form wizard
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
Form creat in flash
  1. Create a new document and set the size to 400 x 300 ("Frame" > "Frame Size")
  2. Set "Frame 1" to "Stop" ("Frame" > "Frame Delay" and check "Stop", click OK)
  3. Draw 2 edit fields with the "Edit field" tool, they will appear as Edit1 and Edit2. Double click each field and make sure HTML is not checked, uncheck if necessary.
  4. Draw a button, double-click it and rename it to "OK".
  5. Draw edit field labels "Phone" and "Email" with the text tool. Double click each field and make sure HTML is not checked, uncheck if necessary.
  6. Draw "ErrorMessage" field with the "Text Paragraph" tool. Choose "Item" > "Text Color" and change it to red. Choose "Item" > "Placement Properties" and rename the field to "ErrorMessage"
    1. Select the button, choose "Item" > "Actions" > "OnClick". Select "ActionScript" and paste the following code:
    // reset error message
    ErrorMessage = "";
    // validate phone field
    phone = Edit1;
    if(phone=="") ErrorMessage = "Enter your phone";
    // validate email field
    email = Edit2;
    if(email=="") ErrorMessage = "Enter your email";
    if(email.indexOf("@",0)<0) ErrorMessage = "Enter valid email";
    if(email.indexOf(".",0)<0) ErrorMessage = "Enter valid email";
    // build message string
    message = "mailto:[email protected]?subject=Title&body=Form contents%0A";
    message = message + "phone: " + phone + "%0A";
    message = message + "email: " + email;
    // execute form if errormessage is empty
    if(ErrorMessage=="") getURL(message,"_self");
Hit F9 to preview. The form will not work until you export Flash file and HTML page. Choose "File" > "Export HTML Page" to create HTML page and test the form in a browser. This form is using very basic validation. Use "%0A" as line separator.
Use the following functions or attributes of the string:
  • length returns the number of characters
  • charAt(x) returns zero-based character at position x
  • indexOf(substring,startindex) returns the position of the first occurrence of the specified substring or -1.
  • lastIndexOf(substring,startindex) returns the position of the last occurrence of the specified substring or -1.
  • substr(start,n) returns n characters string starting at specified position
  • toLowerCase(), toUpperCase() converts the string to lower or upper case
Storage of MS-Access 2007
(please refer for www.office.microsoft.com for further information)
Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
1 page header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
Project specifications The following list of tables is specific to Office Access 2007 projects:
General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
Zulfikar Ali
Hi running word 2003 have an auto fill in the date feature installed on a fax template how do I disable it. if I open up previous documents composed the present date populates yet the document was composed...
This is caused by the document using a "field" and not an actual date. Press <ALT+F9> to see the date's field code. You will probably see: { DATE } or { DATE @ "M/d/yyyy" } (NOTE: The M/d/yyyy formatting may be different for you; since this is personal choice). You can manually delete the field and type in your date. To automate this, open the TEMPLATE (*.DOT) and change the field by using: Insert > Field... and selecting "CreateDate" from the Field names list. Also - set your desired format too and then click <OK>. Save the change to your template and it will use the date you create the fax and keep that date if the fax is saved as a document and reopened in the future.
Relation
populate the field's controlsource with =forms.formname.field and then from the properties of the new field change the format to a required one, on saving it will use that format.
18helpful
3answers
Using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
