Question about Sony Televison & Video
IR remote interference with Sony HDTV
Hi:
I just got a Dish Network DTVPal HDTV DVR recorder (off-air converter box with off-air-only-DVR). The unit's remote only worked at about 1-2'' from the unit. Thinking the stock batteries might be weak I replaced them and then it only worked about 8-10'' from the unit. Note: The lights on the remote all glow brightly with all batteries I tried. Today I tried to turn the unit on before the TV and it came on with no problems. Then I turned on the TV and the DTVPal remote went back to only working at 8-10'' again.
The TV is a Sony KDL-52W4100 and is about 6 months old.
So I began experimenting and found that if the TV's PICTURE (not power) was off either via A) going into ''standby'' (PC input) or B) ''picture off'' (TV's menu setting) the DTVPal's remote worked fine. After resuming normal TV operation, darkening the TV's picture (brightness, contrast, backlight, etc.) had no effect. Shielding (not covering) the DVR's IR sensor (the DVR is on a shelf under the TV) but keeping it in sight of the remote also had no effect.
And today I noticed that there is a time delay after I turn the TV off before the DVR remote will function normally again. I'm not sure how long this is yet, maybe 15-30 minutes. This would tend to rule out anything coming off the screen itself. I also tried covering the front of the TV area around the IR sensors with various items but still had no luck.
Additionally I got a small Samsung HDTV (model 451, 19'' screen) from the bedroom and connected it to the DVR Instead of the Sony TV. All worked fine.
No other remotes (there are 6-10 of them) have any problems with any of my equipment.
Any idea what the TV ''screen'' is putting out that is causing the interference? Or any other way of getting the remote to function? I'm also contacting Dish Network and Sony, but I expect they will each point to the other as the source of the issue.
Thanks,
-Jim Higbee
  • 2920 Answers
SOURCE: My remote does not work for my Apex TV
it may be a time to buy a new tv. it would cost more to fix that one than to buy another tv
Posted on Dec 06, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
  • 374 Answers
SOURCE: DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Posted on Apr 20, 2009
SOURCE: Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Posted on Aug 04, 2009
I need a remote code for my dish network VIP722k DVR with my sony RMVZ320 remote
Check with DiSH for a possibly unpublished code. You may find that only the DiSH remote will work.
Jan 01, 2014 | DISH Network IR Remote Control
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at Cheri.Torres@Dish.com with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
Social Media Representative
DISH L.L.C.
Apr 08, 2012 | DISH Network IR Remote Control
Cannot control it with a RF to IR emitter.
Does the DISH remote work without the emitter? If it does work, then the problem is associated with the emitter. If it doesn't work, do you have fresh batteries in the remote? If you do have fresh batteries, you may need a new remote. Please contact us if you have DISH Network equipment at 1-800-333-3474 or go to www.dishnetwork.com, then click on the Contact Us link under the Support link on the main page. I hope this helps.
Ray Calo
DISH Network
Mar 29, 2011 | DISH Network DTVPal DVR by
I have a 3.2 IR dish network remote. How do I fast forward through commercials on DVR?
you can only fast forward recorded movies. Use the dvr button with the arroww that points to the right.
Feb 26, 2011 | DISH Network IR Remote Control
I get new DTVPal DVR for 2 month. and it can not start. press start on remote. the green light just on less a second and off by it self. who can I get wanrantty, where can I have custom service phone...
Hi this is Mike Houston of DISH Network. I will be more than happy to help you with that phone number 1-800-333-3474. We also have troubleshooting as well on DISH Network and that link is
http://www.dishnetwork.com/supportsection/troubleshoot
Jan 16, 2011 | DISH Network DTVPal DVR by
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Remote control interferes with second TV
si24
It is possible that the 2 remotes are on the same remote address. This generally is not possible if one remote is IR and the other is UHF but with some receivers you can have an UHF remote for you TV 1. To resolve this issue you would need to readdress on of the remotes to a different remote address. I have provided instructions on how to readdress the remote. I hope this helps.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
May 11, 2010 | DISH Network IR Remote Control
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Televison & Video Logo
216 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
