Question about Monarch 9855 Thermal Printer
Paxar 9855 print error
Looking for solution of problem I googled ...I had a hit on your site which is exactly the problem I am having...
Thanking you in advance...
Free tech support for Monarch 9855 Thermal Printer and help with Monarch 9855 Thermal ... a label software application, "label Matrix 5.0" to a Monarch (Paxar) 9855. ... First it says "RX Batch" and then "Batch Line 08, code 400
  • 257 Answers
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Posted on Jun 21, 2009
Check print head #768
This is the error code stating that there are more than 8 print elements faulty and requires replacement.
However if the cabel to printhead is not installed correctly this can also give the same error - check it is fully connected.
Aug 19, 2011 | Monarch Paxar? 9855 Label Printer
Monitor says Ready to print but when I hit F7, nothing happens and error code 101 shows up.
Hi
You have a fatal error
You need to replace printers motherboard
Pls vote us to keep us alive
Nov 21, 2010 | Paxar Monarch 9855 Thermal Printer
Paxar 9855 203dpi printer hd getting problem between 2lack inches pls give me a salution for solve this problem,
you need to have the printhead replaced.
do print test by pressing both arrow buttons at the same time and the unit will do a print test. look for the line BAD DOTS and if the Value is greater than 000 the printhead needs replacing
Feb 18, 2010 | Monarch Paxar 9855 Printer
Where can I buy Paxar Monarch 9855, 9835, 9800 printer spares from
To buy a Paxar Monarch 9855 you can buy it to the nearest appliance center or any electronic center in your place. If you can not see that in your place you can buy it through online. Visit and inquire it in ebay or amazon website.
www.ebay.com or www.amazon.com
Thanks and good luck!
ICman
Dec 23, 2009 | Paxar Monarch 9855 Thermal Printer
How dod you check the configuration and firmware version on the Paxar Monarch 9855?
Perform an internal diagnostics test print. I believe you can press both of the arrow buttons at the same time, and it should print out what's in the printer and how its configured. There you should find the firmware version.
Oct 20, 2009 | Paxar Monarch 9855 Thermal Printer
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Printing duplicate labels. Switched from the 9840
The printer shouldn't print the same barcode twice. As long as the data is exactly the same, and the supplies are exactly the same, these two printers should be acting the same.
Are you using a 3rd party software application or driver? If so, you may need to contact them to help you adjust the issue, but longoftheshort, if the printer details are exact, like above, then the printer is duplicating, likely, because it is being told to do it. Since the printer cannot arbitrarily reprint a label, it must be told to do it. That is either done through data, or it is done because it didn't finish the job on the previous label and may do it on the followup label.
May 13, 2009 | Paxar Monarch 9855 Thermal Printer
Unable to print or only prints one page
My brother dcp tells me
unable to print check troubleshooing and maintenance chapters.
I have done this and cleaned the printer, it also tells me ink jets empty, they are all new ones.
Driving me mad any suggestions so I can get my sanity back.
Thanks
Denise
Jun 12, 2008 | Paxar Monarch 9855 Thermal Printer
Invalid Command
Your 287 error has to do with an incorrect setting for printhead width, and in the control language that your software is sending to the printer, they either have something other than 0, or there is an invalid character like a carriage return or line feed being sent to the printer.
This is a difficult one to trace since the software sends the code and you cannot necessarily change what is being sent.
Please note that the software that you really should be using is PC Mate Plus, as this is a specialized printer for Paxar supplies called Care Labels. You may be able to cheat if your software allows you to select 300DPI print heads. If not, you'll need the software I suggest.
If you do not have this software, please contact Paxar (now Avery Dennison) at 1-800-543-6650 and ask to be connected to someone in technical support or if the customer service rep can offer you a link to a website for software download, or purchase.
Ohiotech
Nov 19, 2007 | Monarch 9855 Thermal Printer
Monarch 9855 Thermal Printer Logo
893 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
