Question about Acer Aspire 5100 Notebook
My pc can not find boot device
Whenever I turn on my pc, I am receiving the following error while booting.
Controller Bus#00, Device#1F, Function#02: 06 Ports, 01 Devices Port-00:
and then "boot device not found" and after restarting, everything works fine. Please help to eliminate this problem...
    Guru:
  • 597 Answers
This means that at times your hard drive can't be found due to either the hard drive not working or that laptop not being able to find the hard drive due to either a motherboard problem or the ribbons that connect the motherboard to the hard drive. This problem will probably continue to escalate until the hard drive, laptop or the ribbon fails. You could try replacing the ribbon first as it's probably the cheapest to replace if you can find one then change the hard drive and if that doesn't fix it wait for the lap top to fail.
Posted on Jun 01, 2009
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
there's a system rechargeable battery inside the PC casing which helps retain system settings. it may have given up the ghost. you could try replacing the battery...
Jun 01, 2009 | Intel DG33BU G33 Express Socket 775 mATX...
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Acer Aspire 5100 Notebook Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
