LEXMARK X1240 WON'T PRINT ENVELOPES
I HAVE TRIED ENDLESSLY TO PRINT A SIMPLE RETURN ADDRESS AND THE ADDRESSEE ON A #10 BUSINESS ENVELOPES I HAVE DONE ALL THE SETTINGS AS PER LEXMARK ON PRINTING ENVELOPES I PLACE THE ENVELOPE ON THE FEEDER STRAIGHT UP ON THE RIGHT SIDE WITH THE PAPER SUPPORT SLIDEN OVER TO HOLD IN PLACE THE PRINTER FEEDS THE ENVELOPE THE PRINTER HEAD GOES THROUGH ALL THE MOTIONS AS IF IT WAS IN FACT PRINTING THE ENVELOPE NUT IT COMES OUT BLANK, I HAVE A BRAND NEW LEXMARK #27 BLACK INK CARTRIDGE INSTALLED AND CAN PRINT DOCUMENTS W/O ANDY PROBLEM, IT JUST WON'T PRINT ENVELOPES, I WAS ON WITH LEXMARK SUPPORT AND THEY WALKED ME TROUGH 3 DIFFERENT PRINTER PROCESSOR SETTINGS AND NONE OF THEM WORKED
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Posted on Mar 01, 2010
    Problem Solver:
  • 10 Answers
I had the same problem; it would print documents but would not address envelopes. Reinstalled the software, no fix. New black cartridge, no fix. I use this printer mainly to address envelopes because my Brother crunches them. I noticed that envelopes were being printed in red print, then nothing. I think the color cartridge is dry but I don't care, I never use the color function anyway. Based on Nancynovice's solution, I made the change to print color images in black and white and walah, fixed. My thoughts are, for some reason the printer decided to print envelopes in color and when the color cartridge went dry, no print. Anyway, worked for me.
Posted on Nov 26, 2011
Envelope orientation wrong for # 10 envelopes
It may be necessary to go back to the initial set up and make sure landscape printing has been selected. Also, envelope feed orientation could be a factor.
Dec 21, 2013 | Mysoftware My MailList & AddressBook...
How to print envelopes
1.Buy envelopes at any office supply store. They come in all shapes, sizes, textures and colors, so choose ones that go with the type of invitation you are sending out.
2.Open Microsoft Word 2007 and click on the Mailings tab.
3.Click on Envelopes in the Create section.
4.Click on the Envelopes tab when the Envelopes and Labels box comes up. The box will probably come up with the Envelopes tab open, so you may not need to do this.
5.Enter the recipient's address in the Delivery Address box. Invitation envelopes should include the names of everyone invited--for example: Mr. and Mrs. Smith, Mrs. Smith and family. Don't worry about the font at this point--you can change it later.
6.Enter your return address in the Return Address box. As with the Delivery Address, you can change the font later.
7.Click on Options. Use the drop-down menu in the Envelope Options tab to change the size of the envelope if needed. The packaging of the envelopes that you purchased will have information about the size of the envelopes. It is very important that you choose the correct size so that the envelopes print correctly.
8.Adjust the font of the delivery and return addresses. Click on Font in each section and change the font style or size. You can also bold, italicize or choose other options regarding the font.
9.Adjust the placement of the delivery and return addresses on the envelopes. In each section, click the arrows in the "From left" or "From top" boxes. In the preview section below, you can see the movement of the addresses as you adjust the placement. Line up everything so that it looks good to you.
10.Click on the Printing Options tab. This is important because you must select how you feed the envelopes into your printer. Choose the correct way that they are fed, whether they are fed into the printer face up or face down, and if they should be fed in manually. This will all depend on your specific printer. Consult your owner's manual for this information if you are unsure. Click OK and you will return to the Envelopes and Labels box.
11.Insert the envelopes into your printer. Click Print once you have everything formatted and arranged how you want. You should print one envelope first to make sure the layout is correct. Once you've confirmed it printed correctly, print all your envelopes.
Sep 21, 2011 | Canon imageRUNNER 1023 Black and White...
How to print both return address and to address on ?size 10 envelopes
Open Microsoft Office Word.
Open File > Page Setup > Paper size > Envelope #10 (in Office Word 2003)
or
Open Page Layout > Size > Envelope #10 (in Office Word 2007 / 2010)
Then type the address like usual typing and print it.
I've found website to do this manually, but I'm not sure what the printer is. You can check out in here :
How do I print on thicker paper, labels and envelopes?
Hope this help, and if you feel helped, RATE please !
Jan 19, 2011 | Lexmark Z600 InkJet Printer
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
How to print #10 envelopes
Here's the link to the Lexmark website to download the Lexmark C543 User's Guide. http://www.lexmark.com/publications/pdfs/2007/c54x/v14841473_en.pdf. There are two ways to print #10 envelopes, using the Multipurpose Feeder or the Manual Feeder. If you don't have the Mulitpurpose Feeder, you have to use the Manual Feeder and feed the envelopes one at a time. Scroll to Page 44 for MPF instructions or Page 46 for Manual Feeder instructions. Hope this helps.
Jun 03, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printing problem
    how can we print a booklet on this printer
    Mar 15, 2009 | Lexmark X1240 All-In-One InkJet Printer
    My lexmark e260dn ps3 will not print envelopes correctly
    THIS PRINTER CANNOT PRINT ENVLOPES, CHECKS, MONEY-ORDERS OR OTHER CUSTOM SIZES.
    I have tried the various drivers, and it just won't print custom size documents, like envelopes, or checks. The From address, typed in the top left corner falls on the top right, the to address typed in the center falls off the page, and so it does not even show up. I just see the word to in the right margin, but the addressee's name and address are missing. I have spent days with tech support and online,without a solution. This printer is a lemon.
    Feb 26, 2009 | Lexmark E260dn Laser Printer
    Printing on a #10 envelope
    Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
    Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
    Typing address on envelopes
    use this link to follow the instructions:http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:488:0:0&framed=&docid=ENUS5124
    Jan 02, 2008 | Lexmark X2350 All-In-One InkJet Printer
    977 people viewed this question
    jasbo
    jasbo
