Question about Samsung HLP4663W 46" Rear Projection HDTV
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
I just replaced a new lamp on my samsung (HL-S4666W)tv. now how to reset the lamp hour meter? thanks Don
  • csea5757 Jun 02, 2009
    Hi asnowman thank you for your help.
    what's the next step after i press option? is there a lamp hour counter reset to zero or somthig? on my tv (HL-S4666W) after i press option i see lamp clear / and lamp life 10538hour.
    thanks
    President:
  • 788 Answers
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
  • John Snow
    John Snow Jun 03, 2009
    You should be able to select lamp clear and enter. That should reset the lamp timer for you. Please update your rating if this fixes your issue, if not please post back to me and I will research some more. asnowman
How do I reset lamp time in Samsung DLP TV- Model HL-R6768W?
http://www.fixyourdlp.com/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter-or-lamp-timer/
Try this link for details.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Televison & Video
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Intermittent black lines samsung hlp5067w
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
Why does my samsung 50 inch hdtv keep turning off .
Try to check the bulb if defective, if the lamp is defective try to replace it, after replacing the lamp be sure to reset the lamp hour meter. good day and best regards. Hope this may help.
Aug 31, 2011 | Samsung HL-R5087W 50" HDTV-Ready...
Tv repeatedly starts at and shutts down. Lamp come on but then shuts down
Those lamps build up a internal resistance and they get to the point where it will not come on at all, replace the lamp, and you will be good.
Oct 18, 2010 | Samsung HL-S4666W Television
Samsung hl-s4666w DLP "Check Fan #2" on-screen message appears before shutting off. How do I fix this?
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Apr 03, 2010 | Samsung HL-S4666W Television
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Set shuts down intertmittently
replace the lamp part # BP96-00826A. if the lamp code on the side of the set is different replace with that lamp. you will need a tech to reset the lamp hour meter in the factory mode.
Dec 31, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
1,782 people viewed this question
Jerry Greenberg
Jerry Greenberg
