Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 streaks on scanning and copying
On page 199 it does not show how to disengage the pick assembly, and nothing I've tried disengages it.  It feels like it will break, so I am not forcing it.  However, my documents are streaking at the farther edges, like approximately 1 inch (2.54 cm) from each edge, so I'm not confident that cleaning that portion of the scanner will resolve the problem..
  • Chrystin Pleasants Oct 23, 2007
    Thanks, it was something on the glass, but it took several times of trying to clean it for the mark to go away and I never actually saw anything on the glass.
    Do you know how to safely disengage the assembly in the document feeder?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Posted on Oct 23, 2007
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 7410 prints OK, but copy and fax comes out black all but 1 inch
The problem is on the scanner...
You have to change "scanner assembly". But... here in Greece this unit has not spare parts.... The repair procedure is "unit exchange". You have to contact HP Service in order to inform you if they can change only the scanner assembly and not whole unit... You can call telephone support.
Apr 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Office Jet 7410 - Streaks in photos
try this link. copy and paste it into your address bar.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00219809&cc=us&lc=en&dlc=en&product=391194&dlc=en&lang=en
also you can search at the top for answers to other problems if this does not help.
Nov 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Blue line vertical on all color copy and scans...help
try this web page, copy and paste the link into address bar. search facilty at top
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+7410+All-in-One&pid=391195&productBigSeriesOid=391192&spid=391194&opname=HP+Officejet+7410+All-in-One&contextual_lname=&pname_desc=HP+Officejet+7410+All-in-One+Printer%2FFax%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Officejet+7410+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=-1&method=prodFinder&qry=blue+vertical+line&Submit.x=0&Submit.y=0&Submit=go
Nov 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Streaks
It sounds like the lamp/light is going out.  Open the top and try to make a copy and see if the light stays on the entire time.
Erice
Oct 29, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Streaking
Check the scanning glass bar. If you scanned something that had whiteout on it, a lot of times some of the whiteout will get on the glass and will cause streaks in the prints. Clean it with alcohol.
Oct 16, 2006 | HP LaserJet 3015 All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
221 people viewed this question
Clive
Clive
