Question about Refrigerators
I put in a new water pump and now I can not get the water filter reset light or the Ice Lock to turn off. I have water to the door but I am not making any ice.
  • jon schreiber Jun 01, 2009
    Thanks for your try on this but I have done all those things. I have a new water filter in there. I have in the past reset the water filter light, the lines are not frozen, I can not get the Ice Off light out nor will the water filter reset light go out. I have turned everything off, taken the water filter out, disconnected the new water pump, then put everything back together and I still get the same lock outs. Is there a "reset" switch hidden somewhere? I have followed the advice of the manula which says to hold the water button for three seconds to "reset" the water filter. That does not work. For the Ice Off light the manual says to hold the Ice Lock button for three seconds and all that does is turn the ice lock on and off.
  • 136 Answers
Ooh sounds like an issue... try unplugging the fridge to get the lights to shut off then plug it back in to attempt to "reset" the fridge or if there is a reset button click it... then make sure the water tubes going into the fridge ar econnected properly... if not there wont be any water to freeze to mak you ice
Posted on Jun 02, 2009
    Sergeant:
  • 296 Answers
Hi
if u cant make the ice,chek the water filter . That will fix the water dispenser,if the ice maker still not working.chek whether the water inlet tube was frozen or clogged or not. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. try pouring hot water over the inlet tube to melt it,if u still find some ice in the tube further back , defrost the freezer so all the ice could melt and turned it back on.ice maker will strat workin.
For Resetting your "change filter" light:
Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
If the fridge has a filter button, press and hold it for 5-10 seconds.
For the ice lock to turn off,chek this link throughly
http://www.ccis.com/home/mnemeth/hints.htm
http://en.allexperts.com/q/Heating-Air-Conditioning-696/index_295.htm
hope u will b satisfied wth the answer
all the best
do let me kno for further developments
thnkyou
Posted on Jun 01, 2009
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How to remove/replace the water filter
If the light on your refrigerator is green, you don't need to change the filter. If it's red, then it's time to change it.
Next, locate the filter knob at the base of the refrigerator. Turn it 1/4 to the left and then pull out the filter. Put in the new filter, then lock it by turning th knob back to the right.
Reset the indication light inside the refrigerator by pushing it 5 times within 10 seconds. The light should then turn green again.
Feb 21, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Put in new water filter
I had to same problem, I had to press and hold the lock and the light button for 3 or 4 seconds. Then it went off!!
Feb 16, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water Filter Red Light
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Jan 12, 2009 | Jenn-Air JCD2290HES Side by Side...
Idicator lights
not a problem aftter inserting the new filter just follow this procedure to reset it..
the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Nov 06, 2007 | Maytag MZD2766GES Side by Side...
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
