Question about Whirlpool LER5636P Electric Dryer
Burning Smell from Belt on Whirlpool Dryer
I changed the belt on my Whirlpool dryer, Model #LER5620KQ1 after the drum stopped turning. Now, the drum will turn when empty, but it makes an awful loud noise. If I fill it with clothes, the drum doesn't turn or barely turns, and I get a burning smell like the belt is burning up. Did I do something wrong when I changed the belt?
  • fbuescher729 Jun 02, 2009
    Thanks for the reply Vic. The idler is a glide style, and the teflon seems to be in good condition. Should I consider replacing with the wheeled idler? I am fairly certain the grooves are facing the drum, but I will check again. I think the loud sound I hear when it turns while empty is the belt slipping, and with the added weight of the clothes, it is too loose to turn at all. Is there anyway to adjust the tension on the belt?
  • Anonymous Mar 15, 2014
    Sounds like something loose & it makes drum get stuck sometimes & burning smell
    President:
  • 1,136 Answers
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Posted on Jun 01, 2009
  • Victor
    Victor Jun 02, 2009
    I would replace the idler to the wheel style.
    After a while, the glide style puts a drag on the belt
    Hope this helps
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
I sensed a bad burning smell from dryer motor. The dryer drum belt is still looking good and tight. The 4 drum rollers supporting the drum are looking good and no friction. The dryer shut itself...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Whirlpool LGB6300 Gas Dryer
My whirlpool ler5620kq1 elec dryer is almost 8 yrs old and I am looking to replace belt and need instructions
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Aug 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer drum stopped when too wet of clothes were put in. Smells like burnt smell. Dryer turns on and heats. Looked for belt but can't locate in Whirlpool dryer I have front off
you have to raise up the top and the drum will just pull off the belt is only about a 1/2 inch wide like a piece of leather possibly laying on bottom under drum
Jul 03, 2009 | Dryers
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
454 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
