Gear oil leaking out
I was transporting my washing machine and somewhere from the bottom where the motor is it has leaked out gear oil. the reason why it leaked out was cause i layed the machine down and i was wondering where do you refill it at.
  • 686 Answers
I have or thought I have posted you a solution. Here goes again. Unfortunately you cannot refill it unless you remove transmission from the washer and then you'll have to open it up to refill it. It's very doable if you are somewhat mechanicaly inclined. Good Luck
Posted on Jun 01, 2009
I have a gs susuki gl 1982 driveshaft that holds 90 weight gear oil thats leaking out of the side by the gear shifter cover is there a seal that can be replaced or does it have a crack in the motor ca
Think the gear change end is not 90 grade oil ,it is 20/50. The bevel drive end is 90 but the motor is 20/50. And there is a seal in the case, unless you have a crack somewhere, depends where the leak is coming from.
Dec 23, 2014 | Motorcycles
My washer has water leaking from motor
There is no way for water to leak from the motor . Check for water running down on the motor from the bottom of the tub. The seal may be bad water is comeing from somewhere else just have to find where it's comeing from. Hope this helps you.
May 16, 2011 | Whirlpool Cabrio WTW6600SBK
Roper washer is leaking above the motor.
Main gasket and seal on the bottom of the machine. You will need to replace the drum gasket and the bearing seal.
May 17, 2010 | Roper RAS8445KQ Top Load Washer
My Whirlpool washer is leaking oil out of the bottom and onto the floor. Model# LHA5500WI. How can I fix this problem? It has a 1/2 hp motor, 1725 rpm, 1440 rpm, rubber mounted.
The leak would be from the gear box. The seals on the gearbox are worn out.
Best to get technician to remove gearbox, and have it reconditioned.
Regards
Ash
Oct 21, 2009 | Whirlpool Washing Machines
Kenmore washer Model 110 suddenly poured oil from the bottom--what happened? It lost oil and my mom continued to use it. We now smell something like burning rubber. The barrel still spins but could the...
You lost a seal in the gear-box, needs a new one, burning rubber smell is from the belt slipping and the gear-box being low on oil giving too much resistance on the belt.
Don't run it until you solve the oil leak and refill with oil
Aug 22, 2009 | Washing Machines
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking oil
The transmission or, gear box housing is compromised. it has cracked for some reason. you will need to replace the transmission in this case.
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Oil leak in washing machine
Sounds like the transmission is leaking. These transmission don't need to be full of oil to function. But, if it's leaking a lot, like tablespoons, it should be checked. It's not the end of the line. Just may need a service call if it's a plentiful leak.
May 05, 2009 | Washing Machines
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
