Question about Maytag Ensignia MAV4758AWW Top Load Washer
Washer shuts itself off
All panel lights will flash then washer will shut itself off after a couple of minutes
  • tinytundra Jun 02, 2009
    I forgot to add there was a power interruption immediately before the panel lights started flashing. Manual states to "reset the software" in the electronic panel, which I did per the instructions and it didn't work.
  • 30 Answers
This maybe a motor going bad because over heating or to hot. Switch inside of motor wareing out or burnt points on switch. See a apppliance repairman to check this out. Hope this may help.
Posted on Jun 02, 2009
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Nov 14, 2007 | Philips 50PF9431D Television
When I start my washer, it runs for a few minutes and then shuts down, When I try to reset it flashes an "E41" on the panel.
I have the same washer the code for that is control board thinks the door switch is open..to repair it said to check pressure switch....something about these washers front door problems.....
Jun 20, 2011 | Frigidaire GLTF2940F Front Load Washer
Started a new wash, started to fill with water then shut down. Now it sometimes turns on but shuts down after about 30 seconnds.
it sounds like there may be a problem with either the control board or the drain pump itself... is it giving you any fault codes at all... you may want to check drain pump on this unit which is located on the front side and requires removing lower panel of unit...check for any obstructions as if unit cannot drain or pump will shut down control assembly... if that looks good then the control board may be faulty unplug unit for a couple of minutes and plug back in sometimes this will reset controller.... repost if anymore questions one of us will be glad to help you out....
Jan 08, 2011 | LG WM-0532HW Front Load Washer
The START indicator lamp flashes and we can't shut it down
In this case, I would try unplugging it (or shutting the circuit breaker off) for about 5 minutes. Then turn it back on to see if the washer panel now functions normally.
I hope this helps your washer get its brains back! :)
-Jason
Dec 14, 2010 | Bauknecht Dishwashers
Washer will not drain, just hums then shuts down
If you put it on wash - does it agitate?
If not - Most likely the coupling is failed.
Any way you look at it - you will need to empty as much water out as you can - because to replace the coupling - the pump must be disconnected.
CLICK HERE to see the coupling.
Another telltale sign of a failed coupling are black rubber bits, and plastic pieces under the washer when you tip it up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 01, 2009 | Whirlpool LSR7333 Top Load Washer
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Display Lights Flashing
try to unplug the power cord for more than a minute to see if the control panel reset itself first
May 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Ensignia MAV4758AWW Top Load Washer Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
