Question about HP Pavilion ze2000 Notebook
Tab key hanging loosely unable to use
The tab key was pulled out accidently..not working
  • 4 Answers
I take it that the TAB key has come loose from the keyboard. Usually when the keys come off a laptop keyboard, they can be clipped back into place. However, the keys usually have a scissor like support on the underside of the key, which have small plastic pins that need to be latched onto the keyboard itself.
To be honest they are a pain to reattach, so if you have the patience and a steady hand, give it a go, otherwise I would get a repair tech/engineer to look at it. It may be that the key is damaged, in which case you will more than likely need to replace the keyboard, as key caps don't usually get sold separately.
Posted on Jun 02, 2009
When I start the car and put it into drive the horn goes on, when I shut the car off the horn sounds! wont go off until I disconnect the battery
You could pull the horn fuse, that should kill it. The horn fuse is hot all the time. Two possibilities, one is security system, the other is problem with horn switch or wiring in the steering column.
The horn switch is ground for the control side of horn relay. Part of key fob security horn beep, is also a ground wire. In the diagram, you can see the two wires, The one for fob, take it loose, see if that stops the horn sounding by accident. Don't leave any live wires hanging loose, use electrical tape or something to insulate. I don't know if taking that one wire loose will cause any problems or not, I guess you can try it and see?
Of course, you still want the horn switch to work normally.
May 14, 2016 | 1999 Oldsmobile Cutlass
How do I put back the ice bucket in my subzero 600 series?
Little late to get an answer. I have a 600. The answer is there is a flap that hangs down from the left. It stays at a 45 deg angle when down. Just gently push the bucket in and the flap will go up. Gently.
Dec 04, 2012 | Sub-Zero 680 / F
I have the iDECT X1i twin - I have accidently put the keypad lock on and am unable to find my user guide. Please advise how I remove this. Thank you
Try the following: press and hold the * button on the keypad to toggle the keypad lock. (There is a small icon that looks like a padlock on the key.) This works on the later X2i model.
For the user's guide, try: http://www.binatonetelecom.com/support/user-guides . Unfortunately, my browsers aren't working through the site properly. I see the X1i on Amazon but not on the Binatone site.
I hope this helps.
Jan 15, 2011 | Cell Phones
In normal mode PC hangs due to spies or viruses. Unable to start the system in safe mode or safe ode in networking mode always it restarts if tried with safe mode. www.kaspersky.com, www.grisoft.com,...
When you are restarting the PC - Press F8 Key till you get the options to Boot
Choose Last Known Good Configuration and load windows
Once you have logged into your PC - try to MSCONFIG
If that does not work, Open Task Manager ( CTRL + ALT + DEL ) key and Click on Services Tab. Click the Services Button below. and it should let you open SERVICES.MSC
Disable all the Antivirus software installed ( double click on the software name and under Startup type - choose Disable )
Also Disable the Windows Installer
Try to access or Download some Virus program to Run or Clean.
Jun 24, 2010 | HP Pavilion a1610n PC Desktop
My hotpoint ultima has stopped halfway through a wash and has the word door flashing.
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Upon placing the key into the ignition, we are unable to turn the ignition to start the car. Most of the time, it works, but sometimes it doesn't. What is causing the ignition not to turn
sounds like the ignition is worn out time to take the car to a lock smith rather than the dealer have then pull the ignition and file the pins if required and re key if required lock smith will charge you 75 bucks a dealer will charge you 250 dam dealerss will never learn
it sounds like the ignition is worn and has a stickey pinc usualy from a lot of keys hanging from it like more than 4 or prolonged use
usualy curriors have this problem too
key in key out 50 - 100 times per day
eithor way good luck
Jan 02, 2010 | 1987 Saab 900
1994 corolla. minor accident pulled rear plastic
check for burnt fuse and wiring damage at bumber causing short condition!
Jun 22, 2009 | 1994 Toyota Corolla
Battery
Several suggestions:
Put 7130 on table face down.
Grab sides of BB with thumb and middle finger of one hand at the bottom of the cover where it has the larger part.
with other hand, use index finder to push down the locking button while shifting with the first hand.
Or:
attach a four inch lenth of scotch tape on the battery cover with the loose end hanging off the bottom to use as a pull tab.
Then use a finger nail to depress the release button just a slight amount. It's important to press down on the top edge of the button. Also it is very important not to press to hard because the amount of downward movement to release it is very small. If you press it down too far it binds and prevents the latch from releasing.
The key is to use the pull tab you made from tape to slide the cover off once you have released the latch.
or:
1. Take a letter opener or a flat head screw driver and push down on the top portion of the tab. The tab is located on the back side of the phone at the bottom.
2. Don't push down to hard
3. While pushing down use your free hands thumb to push down and slide the cover off the bottom of the phone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | RIM Blackberry 7130e Smartphone
Can't get on the internet after installing memory--Did I uplug?
- I would think so that the network cable is unplugged to your computer. Just like a telephone cord,
Mar 09, 2009 | Dell Dimension 8300 PC Desktop
Mouse scrolling probalem
I believe you and I had the same problem. I just figured it out, actually by accident!
In MS-Excel, on the top tool bar (File, Edit, View etc etc.) there should be a tab next to the Help tab, called Window.
Click Window, then look through the drop down until you see UnFreeze Panes (Note that the problem will be fixed if you click UnFreeze Panes, if indeed our problem was the same.)
If you do not see that option "UnFreeze Panes" and instead see Freeze Panes... then I haven't the foggiest how to help. -___-;;
Good Luck!
Feb 25, 2009 | IBM Lenovo Mouse 76H6618
HP Pavilion ze2000 Notebook Logo
187 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
