Question about Frigidaire Kitchen Ranges
Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Both heating elements not working. This is frigidaire electric. Thanks
  • 6,784 Answers
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Posted on Jun 01, 2009
Why won't the lower element heat?
DID U TEST THE NEW ELEMENT B4 TRYING IT? U MIGHT BE SURPRISE. OTHER WISE I WOULD D SAY CHECK THE WIRING AND CONNECTIONS IF ITS NOT WORKING, CHECK FOR VOLTAGE AT THE CONNECTORS?
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Jun 25, 2015 | Ovens
Oven not working everything else works fine
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 13, 2015 | Ovens
Why doesn't the oven work?
THINGS TO CHECK:
the broil element
The bake element
Apr 11, 2015 | Ovens
I have bought a Venini (VOED67SS) double oven and had it for 10months or so. I am having trouble - the upper (top) oven is working but the bottom (main) oven will not work. The control and temp lights do...
THINGS TO CHECK:
the broil element
The bake element
Mar 07, 2015 | Ovens Ovens
Th oven doesnot heat up but the burners work
THINGS TO CHECK:
the broil element
The bake element
Apr 08, 2014 | Frigidaire Ovens
Oven
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven element is sparking
you have a short and need to check it ASAP SHOULD BE ABLE TO VISUALLY INSPECT IT
the broil element
The bake element
Mar 12, 2014 | Frigidaire FGB24S5A Gas Single Oven
Oven element
The bake element
THINGS TO CHECK:
the broil element
Feb 15, 2014 | Frigidaire Ovens
Belling synergie main oven not heating
THINGS TO CHECK:
the broil element
The bake element
Feb 06, 2014 | Belling XOU174 Electric Single Oven
No heat
The home's circuit breaker is not the problem if part of the stove / oven works. What is more likely to be the cause is a problem such as an "open" or "burned out" heating element or socket.
The control is "on" and sending power to the element. The control reports "Preheating" but since the heating element itself is no longer a complete circuit - it fails to heat. As mentioned above, it may be a problem with the socket that the heating element plugs into - but could be a problem with any wire between the control and the heating element.
I would suggest shuting off the circuit breaker for the stove / oven. Check to be sure it is off by turning on a heater that worked previously. If it stays off, you're ready to continue. Carefully inspect the heating element itself for damage. The surface of the heater should be uniform - smooth over the entire length. You may not be able yo view the back side of the heater - but you may be able to run your fingers gently over the surface to feel for damage. If damage is found on the surface, this would indicate that a new element is required. Once replaced, you should expect it to work again as new. If unable find damage, removal and inspection of both the oven's socket and heating element contact blades should be done. If found to be burned or damaged, replacement of the socket, heater or both may be needed.
Obtain replacement parts designed for you make and model stove / range. Contact an appliance repair service if unsure how to check / make these repairs.
I hope this helps & good luck!
Apr 27, 2013 | Bosch Kitchen Ranges
Kitchen Ranges Logo
431 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
