Question about Kenmore 62702 Microwave Oven
No Power I accidentally ran my microwave empty instead of using the timer option. Now the micro wave will not work at all - I checked the outlet and there is power but nothing lights up or works. my Kenmore 721.67601 just stopped working, no lights, no keypad lit up, NOTHING. There is power coming from the outlet, but nothing will work on the micro. Is there a reset button or does anyone know what I can do to have it working again. thanks maria
  • 6,784 Answers
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Posted on Jun 01, 2009
  • Mommy Fix It May 31, 2014
    Other then checking the plug and wall socket...Have you checked the fuse? It's inside under the vent panel. Most hardware stores carry common fuses. REMEMBER to UNPLUG or cut power FIRST!
Reset button
Unplug,then plug back in,wait 10 minutes,or try another outlet,circuit breaker could of turned off at control panel in house,reset it.
Mar 04, 2017 | Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    My daughter wanted to run the timer on the microwave but accidentally ran the oven for 16 minutes. It overheated and blew out. Can this be repaired?
    Your can be repaired, but it's generally not worth the cost. Running the oven empty usually destroys the magnetron tube which generates the microwaves. The tube is replaceable, but it's a costly part. And the repair should be done by a professional because of safety concerns. Between the cost of parts and labor, it's usually not much more (and sometimes even less!) expensive to buy a new oven.
    While the kitchen timer feature of a microwave is handy, many people accidentally kill their ovens this way. You might want to pick up a small digital timer when you shop for a new oven. It's cheap insurance.
    Jan 09, 2011 | KitchenAid Microwave Ovens
    My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
    you mean it want power up or want work when you press the star buttom?
    1. check the fuse if no power.
    2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
    3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
    Oct 30, 2010 | Emerson Microwave Ovens
    My microwave starts however food does not heat up.
    Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
    Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
    Unit is dead after accidentally running it empty.
    If you ran it for that long with nothing inside, there is a good chance it self cooked.
    It can probably be repaired. The economics of the repair is something you will have to judge for yourself.
    To assist you, may i suggest you visit www.repairclinic.com and check on some major parts for your make and model. If the parts = more than 25% of replacement, I think id be moving on. Expect to pay a pro at least $100.00/hr labor. You should NOT do it unless you are skilled at handling delicate and lethal electronics. A microwave can kill. Another thing, after you fix it, you have a lot of $ invested and still have a old machine that ran for 13 + minutes empty.
    Oct 13, 2009 | Microwave Ovens
    Help used micro as timer but pushed start instead now wont work
    Unplug it and try it again, may just need power on off reset
    Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Our oven does not come on at all.
    Hi, the door micro switch not working ,also the fuse need to check if it is fine check power outlet and breaker recock it.
    Jan 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Kenmore 62702 Microwave Oven Logo
    815 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
